Rolfe
Moderator
- Apr 10, 2023
- West Linton, Scotland
- MG4 (2022-2025)
That's actually rather nice. Nicer than I expected.
Would you mind posting where you got them from?
It's just cheapish double sided not 3m vhb or anything, it's the metal clips that seem to be holding it firmly in placeI'll probably get those ones but I'll wait until the weather gets warmer because I would have to fit them outside and IIRC those double sided adhesives need a warm day of around 20 deg C to cure properly.
Can't say I've had a problem seeing the mirrors.... but interesting to see your results after Mod.They fit great but I have found an issue that I can easily rectify though. The driver's side deflector partially eats in to the view of the wing mirror so I'm gonna fettle/dress off up to the red lineView attachment 24568
You might find a Dremel with a cutting disc and a steady hand works well. I know when I had to recently trim some corrugated plastic roofing sheets it cut easily without splitting the aged plastic.They fit great but I have found an issue that I can easily rectify though. The driver's side deflector partially eats in to the view of the wing mirror so I'm gonna fettle/dress off up to the red lineView attachment 24568
I'll remove them both as I'll have to trim both sides to be symmetrical otherwise it'll drive me nuts. I'll use one of the rotary files at work as that will cause less heat when removing the material then finish off with a half round hand file, I'll then replace the double sided tapeYou might find a Dremel with a cutting disc and a steady hand works well. I know when I had to recently trim some corrugated plastic roofing sheets it cut easily without splitting the aged plastic.
They do front and rear, check out my earlier post with photos of them fittedTeam Heko do them for MG4 now but only for the front at the moment
Could you just cut them off straight, removing the downward section altogether, or is it part of the mounting fixtures ?They fit great but I have found an issue that I can easily rectify though. The driver's side deflector partially eats in to the view of the wing mirror so I'm gonna fettle/dress off up to the red lineView attachment 24568
I can personally say the Mazda driver assist systems are amazing. Are you modding the mx5 like remapping etcGood stuff nice to see someone has developed some. They will have to wait for me as ive just bought a new shape MX5 which i buying bits for. Much more fun and far less likely to kill me with all these ridiculous driver assists.
Do the Hekos make a big difference to the wind noise?Team HEKO Fitted.... Very NiceView attachment 24567ce...
