Ayoull
Technically yes, as all it would need is the OBC and CCU upgrading to 3ph ones from a donor MG4 with them, but would most likely need to be paired with the car which MG wouldn't do
If you mean faster AC charging, no. At least not without considerable difficulty and cost. In practice you would need to upgrade to a car with an onboard 3-phase charger.can a 7kw charging car be upgraded to support higher rate of charging?
Technically you could convert your MG4 into a plane, it would just need a few extra parts and controls. However, that doesn't mean it is practical in most situations.Technically yes, as all it would need is the OBC and CCU upgrading to 3ph ones from a donor MG4 with them, but would most likely need to be paired with the car which MG wouldn't do
Tad easier to upgrade a 1ph MG4 to 3ph, opposed to converting it into a plane.Technically you could convert your MG4 into a plane, it would just need a few extra parts and controls. However, that doesn't mean it is practical in most situations.
That's right a 3ph OBC is just 3x 1ph 3.6kW units, and when on a 1ph supply the OBC bonds 2 of the units together to allow 7.2kW at 1ph.I believe that any 11kW on-board charger is just that: 3 3.5kW charging units, but in one box.
No it isn't due to the software side.Tad easier to upgrade a 1ph MG4 to 3ph, opposed to converting it into a plane.
So a silly comparison really
Never said it was a simple user upgrade it's you that's inferred that just now.No it isn't due to the software side.
Pretending this is a simple user upgrade is silly.
It is misleading to others until someone has proven it is a user option. I said 'No' because that's the right answer today. Your speculation made it sound easy but you don't know it is as simple as you laid out.Never said it was a simple user upgrade it's you that's inferred that just now.
