johnb80
- May 22, 2023
- Gainsborough, Lincolnshire
- MG5
Absolutely correct.Warranty documents are an aside. Under uk law items must be fit for purpose, they can have one go at fixing, if not successful then you have a right for full refund or replacement, this is up to 6 years. You can require them to agree to independent arbitration prior to small claims court hearing. If they refuse then this is frowned on by the courts and they are likely to loose. Most will offer full refund or replacement at this stage, including Samsung who I also got a full refund for a Tv after 3 years
Not according to MG7 years, But only on pin hole corrosion! Most everything else is 12months .
and if they try and refuse on any item that it is reasonable to expect it to work for longer fault free, use the legal process, dont just sit back and have your tummy tickled.
It is entirely possible that both the judge and me were wrong..... or you might be wrong? Searching the confirms that 6 years (5 in Scotland) is the general accepted period that a TV should last.@johnb80:
Sorry but you're wrong* (or the judge was misinformed). The legislation that applies in the UK is the Consumer Rights Act 2015. I suggest you read it and the associated Explanatory Notes.
Nope, I never buy extended warranties on item, theres no need, 6 years is plenty for my TV etc which I'm entitled to free of charge.However if the TV was offered with an extended warranty (e.g. John Lewis used to offer 5 year warranties; Richer Sounds 6 year warranties) then the terms of said warranty would apply - if you'd complied with them and the retailer hadn't then your assertion would be correct - but that's not the angle you stated.
Yes indeed and theres a straight forward legal procedure for the retailer to transfer the liability to their supplier. I've done this a couple of times in my business with full co-operation of the purchaser. We sort out the client, get them back up and running again and then go through the paperwork for us to get compensated.* other than regarding the Defendant - I'd assumed you'd bought direct from Samsung; of course if you bought from a retailer then they would be the Defendant.
