Can any one [charging stops at 80% although set to go to 100%]
Deleted member 16414
Hi I got mg4 1 trophy long range set the power to 100 but it still stops at 80 percent
Is your app functioning m8?
Perhaps that's at 80%
Not sure that would override the setting you put on the charge screen but I can't think of anything else.
More Learn ed Types will be along shortly.
I think thats how it works "et the power to 100 but it still stops at 80 percent", we have an LFP (basic SR) system so can't stop it to 100%? (unless via the charger on the wall)
We don't have a wide variety of different charger type experiences, but we have noticed that PodPoint rapid chargers always stop at 80% no matter what the app is set to. Other rapid we use take the car to 100% so it's not an app/car setting. Maybe that's the issue with what you are seeing?
yes you have 2 basic systems either the car or charger. We've only ever used that charger (ohme) to run/drive the system, which always does as its told (in our case)
Is the 100% set in the car or the iSmart app?
Check the setting in the app. On the home screen tap the battery tile, tap the nut icon at the top right and check what the Target Battery Level is set at.
    Votes: 946 77.6%
    Votes: 181 14.8%
    Votes: 92 7.5%
