AndyL61
- Oct 16, 2022
- Location
- Stoke-on-Trent. England
- MG4 Trophy LR
This is mine.
I have a LR yes.
I have a LR yes.
Seems to be an MG5 thing. There are posts about this on the MG5 forumShould my fuel % icon not say battery %. Is this why it won’t click over to allow me to change the charge level?
So is it the % "wheel" that do not turn, or is it that it's falling to store/confirm the % setting you choose?I have a LR and it’s not on my app anymore since the update? There is now no charging management screen. Not sure what to do now
That video must be for the old app. The new app doesn't have the triangle slider. If you have an SE SR you cannot change the charge limit below 100% anyway.Thanks everyone in here. I have been madly pressing everywhere on the screen because the little info tags are there but nothing else. Looked up a youtube vid and saw the triangle slider which mine doesn’t have. Hmmm standard range…
SR SE does not have (need) the ability to stop the charge at a set percentage as it has a different battery type to the long range version.Thanks everyone in here. I have been madly pressing everywhere on the screen because the little info tags are there but nothing else. Looked up a youtube vid and saw the triangle slider which mine doesn’t have. Hmmm standard range…
I understand the difference between NMC & LFP however there are times when I just want a certain SOC for the morning. In my case most of my charging is done from my rooftop PV (very sunny place). I might get to 70% via PV by 1600 then want to get to 80% on off peak starting at midnight but minimise having to pay for the ‘top up’ by not going past 80%SR SE does not have (need) the ability to stop the charge at a set percentage as it has a different battery type to the long range version.
You could do that if you had a smart EVSE ,which would be able to charge to a set limit.I understand the difference between NMC & LFP however there are times when I just want a certain SOC for the morning. In my case most of my charging is done from my rooftop PV (very sunny place). I might get to 70% via PV by 1600 then want to get to 80% on off peak starting at midnight but minimise having to pay for the ‘top up’ by not going past 80%
Yes of course, as long as it is able to communicate with the bms, however just loading the LR software on the vehicle should be simpler and cheaper. The screen already has the 80-100 zone delineated differently.You could do that if you had a smart EVSE ,which would be able to charge to a set limit.
Although according to the manual the bms tells you to perform a slow balance charge when required. I haven’t owned the vehicle long enough to see it this actually happens.I agree, it would be handy sometimes. I have a suspicion they may have removed the facility from the SR to try to prevent people mistakenly treating the batteries as if they were NMC and never letting them balance properly.
Yes the standard range is lfpDoes your car have an LFP battery?
Interesting, maybe coz mg4?I have reinstalled the ismart app and the battery target triangle (old version in Oz) is back.
