Walespete
Age
66
Llandudno, Wales, UK
MG4 (2022-2025)
Came back from a trip yesterday with 14% left. Went to charge the car but it refused to connect to my Podpoint charger.
The charge port colour was white. When I plugged in it stayed white. I locked the car. 30 seconds later the white light went off. No lights at all. Unplugged.
Unlock car, wake it up, went to plug in again but there were no lights. Left it locked and unplugged for 3 minutes and tried again. After 30 seconds the white light went off, no connection.
Any ideas please? If all else fails I will try my local (and expensive) DC charger.
If this is a permanent issue maybe try to unplug the 12v Battery for an hour or so. If that doesn't do it maybe ask your dealer to redeploy/update the Software for either the CCU (CombinedChargingUnit) or the BMS (BatteryManagementSystem).
Are you sure either the car or the point
Are you sure your car or your pod point timers are not set?
They weren't last night when it didn't work. This morning I hit boost charge in the Podpoint app. The light went green on the 3td charging attempt.
I'll leave it now to do its thing. Only issue is that it's 29.7p per KW rather than 6.7p 😭
    Votes: 1,071 77.8%
    Votes: 207 15.0%
    Votes: 100 7.3%
