If I've got this right, the Luxury is equivalent to the Trophy in this country, and it has a 64 kwh NMC battery pack. Lots of people on the forum have these and you will get some great advice.
This is, as you have guessed, the type of battery where you should be careful about charging it to 100%. That does not mean that you shouldn't do it though. The advice about these batteries is not to leave the car unused with the battery at 100% (or indeed over 80%) for days or weeks at a time. There is no harm in charging up to 100% if you intend very soon to drive the car and bring the state of charge down again.
Most people who aren't driving long distances every day charge to 80% routinely, then let the battery fall no lower than 20% before charging again. So for ordinary use you cycle the battery between 20% and 80%. However the remainder of the charge is there for you to use on longer trips (or even daily if you drive a long way every day). Just bring the battery to 100% the night before your planned trip. And of course out on the road, if you go very low, charge soon, don't leave the car parked very low for a long time.
Another point to remember is that it's good to charge the car to 100% about once a month and let it sit on the charger long enough to balance the battery pack. You should try to do this before you have a trip planned that will take the battery back below 80%. Also, two or three times a year, drop the charge below 10%, let the car sit like that for perhaps two hours, then charge it to 100% and let it balance in a single uninterrupted AC charge. This is good to calibrate the range indicator.
But finally, a number of people who have done none of this, but have done everything we're told is not good for the battery, still say their cars are absolutely fine and not to worry.
