NickHeynes
- Jun 19, 2022
- Location
- Benfleet UK
- MG4 SE SR
I wonder where that leaves the lease companies?This from my dealer:
A Faraday cage sock will be needed these days!My spare ended up IN a sock the last time I looked for it. Good luck
Not if you buy an MG4 SEA Faraday cage sock will be needed these days!
Update:- Key found, alongside the V5.My spare ended up IN a sock the last time I looked for it. Good luck
I know we are joking about socks here, but I’m pretty sure they all have keyless entry/start? But the Trophy also had Bluetooth phone keyNot if you buy an MG4 SE
I can't find it now but I'm sure I read SE doesn't have keyless entry, but does have keyless start. I could be incorrect, really we could do we an improved feature chart on the MG website.I know we are joking about socks here, but I’m pretty sure they all have keyless entry/start? But the Trophy also had Bluetooth phone key
Yes you’re right about the chart, they seem to have been tweaking it since it went liveI can't find it now but I'm sure I read SE doesn't have keyless entry, but does have keyless start. I could be incorrect, really we could do we an improved feature chart on the MG website.
This began because I couldn't find the spare key for my current Renault Zoe, meaning I'd be significantly out of pocket when it comes time to replace it with an MG4.I know we are joking about socks here, but I’m pretty sure they all have keyless entry/start? But the Trophy also had Bluetooth phone key
Yes I saw the buttonless start too. I’m now wondering how you turn it off, or do you just walk away..All MG4 have a buttonless start - apparently they have deleted the Start button and you just press the brake pedal instead - but the key or appropriate mobile phone on the Trophy must be present.
If it’s like the VW, you just walk away. It’s pressure activated by the driver’s seat. As soon as you get out it switches off.Yes I saw the buttonless start too. I’m now wondering how you turn it off, or do you just walk away..
Not if the boot time is as quick as it is in my wife's XC40 electric, with the same system. It's on in the time it takes you to sit in and select a gear (Drive or Reverse).That's a PITA if you regularly need to get out to open gates.
Similar to the Tesla facility then ?.Not if the boot time is as quick as it is in my wife's XC40 electric, with the same system. It's on in the time it takes you to sit in and select a gear (Drive or Reverse).
It works similar to the Tesla facility then ?.Not if the boot time is as quick as it is in my wife's XC40 electric, with the same system. It's on in the time it takes you to sit in and select a gear (Drive or Reverse).
Yep. Makes for a swift egress/exit without any of the security issues of leaving a car on and unattended.Similar to the Tesla facility then ?.
