jamesc83
- Jun 10, 2021
- Birmingham, UK
- MG4 (2022-2025)
Well my install seems ok but Im just going off what my installer said.James, just fitting mine and the switched fuse stays live when the car is locked - mg4 trophy
It does monitor the voltage too and will turn off when the below 12v.
Also the car itself monitors the voltage and top the battery up every so often, you can tell it’s doing this as it shows 14v in the app. It’s possible switched becomes live when this is happening.
Installer has actually just posted about it here.
MG4 Dash cam install
This customer had front & rear discrete Goluk Dashcams installed into his previous vehicle and has since replaced that with a brand new MG4 EV.We gladly obliged to refit the original dash cams including new cables and hardwire kit so that he can benefit from parking mode on the cameras.Even...
www.dashcams.co.uk
Also not sure if it was clear or not but he used empty fuse slots, rather than tapping existing fuses.Well my install seems ok but Im just going off what my installer said.
