Has Anyone played around with HomeASSISTANT addon for the MG4 ???
Which home assistant system are you using?
MG / SAIC - Custom Integration or the SAIC MQTT Gateway (Python) addon?
I'm using the MG/SAIC - Custom Integration .. just now trying to use the Phyton one ...
I found this guide to installation very helpful:
What graphic/template are you using?
I copied someone else's idea from a forum somewhere and adapted it. Will need the mushroom cards added to your system.
I just grabbed an overhead image of a car from googling, saved it into the HA files section where your images are kept, and overlayed some data on that.
It sits in a panel/single card dashboard. Looks not so good on a computer screen but works well on a phone screen, which it this dashboard's purpose.
Play round with the top and left position % numbers to move the little info cards about to fit your own example. They operate as coordinates from the top left corner. IOW 0% left + 0% top = top left corner, 100% left + 100% right = bottom right corner.
yaml (replace the "xxxxx" sensors with those for your vehicle):
YAML:
type: vertical-stack
cards:
  - type: horizontal-stack
    cards:
      - type: gauge
        entity: sensor.xxxxx_soc
        needle: true
        segments:
            color: "#FF0000"
            color: "#FF0F00"
            color: "#FF1E00"
            color: "#FF2D00"
            color: "#FF3C00"
            color: "#FF4B00"
            color: "#FF5A00"
            color: "#FF6900"
            color: "#FF7800"
            color: "#FF8700"
            color: "#FF9600"
            color: "#FFA500"
            color: "#FFB400"
            color: "#FFC300"
            color: "#FFD200"
            color: "#FFE100"
            color: "#FFF000"
            color: "#FFFF00"
            color: "#F7FD00"
            color: "#F0FC00"
            color: "#E9FA00"
            color: "#E1F900"
            color: "#DAF701"
            color: "#D3F601"
            color: "#CCF401"
            color: "#C4F301"
            color: "#BDF101"
            color: "#B6F002"
            color: "#AEEE02"
            color: "#A7ED02"
            color: "#A0EC02"
            color: "#99EA02"
            color: "#91E903"
            color: "#8AE703"
            color: "#83E603"
            color: "#7BE403"
            color: "#74E303"
            color: "#6DE104"
            color: "#66E004"
            color: "#5EDE04"
            color: "#57DD04"
            color: "#50DC04"
            color: "#48DA05"
            color: "#41D905"
            color: "#3AD705"
            color: "#33D605"
            color: "#2BD405"
            color: "#24D306"
            color: "#1DD106"
            color: "#15D006"
            color: "#0ECE06"
            color: "#07CD06"
            color: "#00CC07"
            color: "#08C410"
            color: "#10BC19"
            color: "#18B422"
            color: "#20AC2B"
            color: "#28A434"
            color: "#309C3D"
            color: "#389446"
            color: "#408C4F"
            color: "#488458"
            color: "#507C61"
            color: "#58746A"
            color: "#606C73"
            color: "#68647C"
            color: "#705C85"
            color: "#78548E"
            color: "#804C97"
            color: "#8845A1"
        unit: "%"
      - type: tile
        entity: sensor.xxxxx_range
        icon: mdi:map-marker-distance
        vertical: true
        features_position: bottom
      - type: custom:mushroom-entity-card
        layout: vertical
        entity: sensor.xxxxx_auxiliary_battery_voltage
    cards:
        layout: vertical
        primary_info: none
        entity: binary_sensor.xxxxx_charger_connected
        layout: vertical
        primary_info: none
        entity: switch.xxxxx_charging
        layout: vertical
        primary_info: none
        entity: sensor.xxxxx_power
    cards:
      - type: thermostat
        show_current_as_primary: true
        features:
          - type: climate-hvac-modes
            hvac_modes:
              - "off"
              - auto
        entity: climate.xxxxx_vehicle_climate
      - type: vertical-stack
        cards:
          - type: custom:mushroom-lock-card
            entity: lock.xxxxx_doors_lock
            entity: lock.xxxxx_boot_lock
          - type: tile
            entity: sensor.xxxxx_mileage
            icon: mdi:counter
            show_entity_picture: false
            vertical: false
            color: accent
  - type: picture-elements
    image: local/community/MG-ZS-EV-Secundrabad-2.png
    elements:
      - type: state-badge
        style:
          top: 15%
          left: 44%
          "--ha-label-badge-title-font-size": 0em
      - type: state-badge
        style:
          top: 15%
          left: 56%
      - type: state-icon
        entity: binary_sensor.xxxxx_battery_charging
        style:
          top: 14.5%
          left: 50%
      - type: state-badge
        style:
          top: 45%
          left: 90%
      - type: state-badge
        style:
          top: 90%
          left: 50%
      - type: state-badge
        style:
          top: 33%
          left: 56%
      - type: state-badge
        entity: sensor.xxxxx_interior_temperature
        style:
          top: 33%
          left: 44%
      - type: state-badge
        entity: sensor.xxxxx_tyres_front_left_pressure
        style:
          top: 25%
          left: 13%
      - type: state-badge
        entity: sensor.xxxxx_tyres_front_right_pressure
        style:
          top: 25%
          left: 86%
      - type: state-badge
        entity: sensor.xxxxx_tyres_rear_left_pressure
        style:
          top: 77%
          left: 13%
      - type: state-badge
        entity: sensor.xxxxx_tyres_rear_right_pressure
        style:
          top: 77%
          left: 86%
I copied someone else's idea from a forum somewhere and adapted it...
YAML:
cards:
    cards:
      - type: gauge
        needle: true
        segments:
            color: "#FF0000"
            color: "#FF0F00"
            color: "#FF1E00"
            color: "#FF2D00"
            color: "#FF3C00"
            color: "#FF4B00"
            color: "#FF5A00"
            color: "#FF6900"
            color: "#FF7800"
            color: "#FF8700"
            color: "#FF9600"
            color: "#FFA500"
            color: "#FFB400"
            color: "#FFC300"
            color: "#FFD200"
            color: "#FFE100"
            color: "#FFF000"
            color: "#FFFF00"
            color: "#F7FD00"
            color: "#F0FC00"
            color: "#E9FA00"
            color: "#E1F900"
            color: "#DAF701"
            color: "#D3F601"
            color: "#CCF401"
            color: "#C4F301"
            color: "#BDF101"
            color: "#B6F002"
            color: "#AEEE02"
            color: "#A7ED02"
            color: "#A0EC02"
            color: "#99EA02"
            color: "#91E903"
            color: "#8AE703"
            color: "#83E603"
            color: "#7BE403"
            color: "#74E303"
            color: "#6DE104"
            color: "#66E004"
            color: "#5EDE04"
            color: "#57DD04"
            color: "#50DC04"
            color: "#48DA05"
            color: "#41D905"
            color: "#3AD705"
            color: "#33D605"
            color: "#2BD405"
            color: "#24D306"
            color: "#1DD106"
            color: "#15D006"
            color: "#0ECE06"
            color: "#07CD06"
            color: "#00CC07"
            color: "#08C410"
            color: "#10BC19"
            color: "#18B422"
            color: "#20AC2B"
            color: "#28A434"
            color: "#309C3D"
            color: "#389446"
            color: "#408C4F"
            color: "#488458"
            color: "#507C61"
            color: "#58746A"
            color: "#606C73"
            color: "#68647C"
            color: "#705C85"
            color: "#78548E"
            color: "#804C97"
            color: "#8845A1"
@wattmatters I just added your gauge to one of my dashboards:
Showed it to my other half, and then showed her the code.
She said "Bl**dy h*ll! He must have even more time on his hands than you."
YAML:
cards:
    cards:
      - type: gauge
        needle: true
        segments:
            color: "#FF0000"
            color: "#FF0F00"
            color: "#FF1E00"
            color: "#FF2D00"
            color: "#FF3C00"
            color: "#FF4B00"
            color: "#FF5A00"
            color: "#FF6900"
            color: "#FF7800"
            color: "#FF8700"
            color: "#FF9600"
            color: "#FFA500"
            color: "#FFB400"
            color: "#FFC300"
            color: "#FFD200"
            color: "#FFE100"
            color: "#FFF000"
            color: "#FFFF00"
            color: "#F7FD00"
            color: "#F0FC00"
            color: "#E9FA00"
            color: "#E1F900"
            color: "#DAF701"
            color: "#D3F601"
            color: "#CCF401"
            color: "#C4F301"
            color: "#BDF101"
            color: "#B6F002"
            color: "#AEEE02"
            color: "#A7ED02"
            color: "#A0EC02"
            color: "#99EA02"
            color: "#91E903"
            color: "#8AE703"
            color: "#83E603"
            color: "#7BE403"
            color: "#74E303"
            color: "#6DE104"
            color: "#66E004"
            color: "#5EDE04"
            color: "#57DD04"
            color: "#50DC04"
            color: "#48DA05"
            color: "#41D905"
            color: "#3AD705"
            color: "#33D605"
            color: "#2BD405"
            color: "#24D306"
            color: "#1DD106"
            color: "#15D006"
            color: "#0ECE06"
            color: "#07CD06"
            color: "#00CC07"
            color: "#08C410"
            color: "#10BC19"
            color: "#18B422"
            color: "#20AC2B"
            color: "#28A434"
            color: "#309C3D"
            color: "#389446"
            color: "#408C4F"
            color: "#488458"
            color: "#507C61"
            color: "#58746A"
            color: "#606C73"
            color: "#68647C"
            color: "#705C85"
            color: "#78548E"
            color: "#804C97"
            color: "#8845A1"
        unit: "%"
      - type: tile
        vertical: true
        layout: vertical
    cards:
        layout: vertical
        primary_info: none
        layout: vertical
        primary_info: none
        layout: vertical
        primary_info: none
    cards:
      - type: thermostat
        features:
            hvac_modes:
              - "off"
              - auto
        cards:
          - type: tile
            icon: mdi:counter
            vertical: false
            color: accent
    elements:
      - type: state-badge
        style:
          top: 15%
          left: 44%
      - type: state-badge
        style:
          top: 15%
          left: 56%
      - type: state-icon
        style:
          top: 14.5%
          left: 50%
      - type: state-badge
        style:
          top: 45%
          left: 90%
      - type: state-badge
        style:
          top: 90%
          left: 50%
      - type: state-badge
        style:
          top: 33%
          left: 56%
      - type: state-badge
        style:
          top: 33%
          left: 44%
      - type: state-badge
        style:
          top: 25%
          left: 13%
      - type: state-badge
        style:
          top: 25%
          left: 86%
      - type: state-badge
        style:
          top: 77%
          left: 13%
      - type: state-badge
        style:
          top: 77%
          left: 86%
Thank you!
My dirty little secret:
there's something wrong with my account .. it started since last Saturday when I can't connect to the car .. then on Sunday, I can't login to the app using my account.
So I initiate the binding procedure, wait for 72 hours (which was a few minutes ago) and rebind with the car ...
Now I can login to the app, but I can't refresh the status of the car The apps says that the last update was last Sunday ..
also now I need to login using my phone number where before I can use my email address ..
and I still can't login using the HA integration (it says, wrong password) ..
Try setting up the MQTT add on. Follow the guide I suggested to you in an earlier post.
yes ... doing that now ... need to setup a few things first ..
I'm in :) I can see the VIN of the car, so I know it's connected .. although I don't see the stats (batt SOC, etc)
I think it's much more powerful than the custom integration. :)
I took the car for a drive ... and now data is IN :D
time to adjust all of the automation and cards I've made ...
Great!
It's also worth mentioning that the custom integration is no longer being maintained, whereas the MQTT system is. (There have been several updates quite recently.)
Great!
It's also worth mentioning that custom integration is no longer being maintained, whereas the MQTT system is. (There have been several updates quite recently.)
yea .. I just read that the original maintainer no longer has the car ...
btw .. if I understand correctly, we can use this to send our data to ABRP right ? are you using it ?
Sorry - don't know anything about that. You should ask about that on the home assistant forum.
Just set up another Home Assistant phone dashboard for my wife to use. Only image I could find isn't really her specific model but it's close enough (same colour).
inspired by you, I created these 2 dashboards .. one to be viewed on my phone (basically replacing the MG app) and the other on my smart-screen tablet ...
thanks a lot ..
    Votes: 1,057 77.6%
    Votes: 207 15.2%
    Votes: 99 7.3%
