Alan5
I have always mainly used my supplied granny charger , because at work I can plug it in a couple of times a week for the whole day for free , but I have noticed recently that the 3 pin plug after a day's charge has been getting hotter than before to the point that the metal pins are too hot to touch after unplugging. I know that other forum members have mentioned about changing the 3 pin plug , which I decided to do with a heavy duty one (still very tight to fit the wires in) charged the next day for around 7 hrs , unplugged and found the new plug was not even warm , so I cut the original plug open and found the live wire to be crimped in place and not even crimped that tight it was very easy to pull out , so I do recommend to change the plug if other users feel the 3 pin plug is hotter than they expect after a long charge and if the granny charger is what they use most of the time
