- Jun 13, 2022
- Location
- Paignton, UK
- MG4
No, it wasn't that post, the advice I am talking about was months ago before you joined the forums. But it doesn't really matter when... it shows - as you say - that people are not clear on what is expected.And that was the initial post I responded to as being incorrect advice. And the subsequent adamant assertions that it was endorsed by Octopus as the correct way to use the tariff. Which it now has been confirmed by Octopus as it clearly isn't.
I still disagree. The only things that work for mass market solutions are extremely simple and obvious to use. The idea that the average person would diligently worry about getting their SOC right every day is for the birds. I still maintain that you are part of an early adopter community that have been following the rules for 18 months but still are not representative of the population at large.The Ohme integration is at least 18mths past the early adopter stage now. I can only go by the experience of being the Admin of that FB group and 6.5k members - 95%+ 'get it' and don't see it as any hassle at all to quickly adjust the amount required. You don't need to be exact, if you need 40% and the app is set to 50% then thats not an issue. It would be an issue if you needed 20% and the app is set to 100% though and you did this every day. With the new Ohme app you can do it after you plug in as well, you don't have to do it before you plug in. But you can do that with the Zappi intgeration in the Octopus app as well.
I would have no problem if Octopus said this is a small-scale tariff only for the diligent and not for mass market use. Arguably that is the case already with it being experimental.
