- Aug 7, 2019
- Location
- Birmingham, UK
- Not an MG
While I don't know for sure, I'm guessing that the intention of the tariff is to supply off peak electricity to conveniently and cheaply charge EVs at home to encourage EV adoption and also balance power use by planning when the electricity is used.You do make a good point, however, in terms of fairness the guy round the corner with his Taycan needing 80kWh and his neighbour with a Outlander PHEV requiring 12 kWh to achieve 100% how can you differentiate between them. Individual customer demands can be massively different.
The point is not how many kWh are delivered, it's the intended use and when. The off peak tariff exists to encourage use off peak, and not during peak hours at a cheap rate. Whether you need 12 or 80 kWh to charge your car is not as important as it serving its purpose to encourage EV adoption. In my opinion.
3 phase connections are very much used in domestic homes. It was suggested by the Renewable Energy Association in 2018.I doubt there are many domestic 11 or 22kW EVSE in the UK. And it is a domestic tariff.
REA calls for three phase connections for all new homes to unlock solar deployment
All new housing developments should be fitted with three-phase electricity supply instead of the current practice of ‘lowest cost’ single phase supply to allow greater deployment of residential solar, according to a new report out today.
The growing call for three-phase electricity in the UK | GivEnergy
UK homes use pre-WWII electrical standards. As we increasingly electrify our lives, the call for three-phase electricity is rising.
It's true that there are not as many as there should be given the requirement for EV chargers for all new cars from 2030 (thank you, Labour) and air source heat pumps are to replace gas boilers in new installations from next year, but having a 22kW charger is and will increasingly be a perfectly acceptable use case.
My battery is 75kWh and since my car can take 16kW, it means I can charge it at a bit more than twice the speed of a 7kW charger. I would actually prefer to charge it as slowly as possible provided it has sufficient charge at the end of the session as that's better for the battery health.
