Rolfe
Moderator
- Apr 10, 2023
- West Linton, Scotland
- MG4
Oh, tell me about it! I came from a 2009 (ICE) Golf, and it's like a different world.
I came from Hyundai Ioniq , had to turn LKA off each time but the difference was that they supplied a one touch button to turn it on and off so it was much easier.Hello I'm new here, having just taken delivery of my MG4 Trophy Long Range on Tuesday. At hand over by the dealer, they recommended turning off on driving on country roads...but it turns itself back on! I think I"ll follow Rolfe's advice. I've said elsewhere on the Forum, I had a Hyundai Kona 64kwh EV and when you set something, 'Drive Mode' for example, it stays set, not like the MG, where you have to keep setting it. I've followed dealers advice and set the 'star' button to change it on the steering wheel, but I'll hopefully get used to it. Good Forum.
Has anyone else had the LKA and FCA turn themselves back on whilst driving after disabling them, this has happened several times and seems to coincide with engaging cruise control, guessing it’s a bug in the software but only happens every now and then.There isn't one. Turn it off before you start, every time. Takes a couple of seconds, but then you're safe.
So do I in my Trophy. LKA stays off.If I turn off LKA (in my SE) I still have ACC. ?![]()
You can turn the sensitivity down and it keeps your setting on restarting. Mine's ok since I turned it down.I don't understand how they still can't role out an update to tame the aggressiveness of this, the fix is there not everyone's is trying to kill them so fix them.
I had this on my Arteon wasn't aggressive or intrusive in anyway, also had a physical button to turn it off.
Have it on my etech again not aggressive or intrusive in anyway, again a physical button to switch it off.
If ncap are insisting on it defaulting to on then MG should be forced into making sure it's safe on all cars, especially because of the lack of a physical on/off button.
Hopefully it's the safe version in the X Power what a feeling that would be flooring it and the car yanking you into the other lane or the verge.
