Locked out
I can see only one person who has implied it didn't happen and they were admonished for it.
But no, no-one else has reported a similar situation.
Very unlucky :oops:
I have actually found a few posts now on this forum describing similar situation - all specifically mention car locking out with a key in a boot and so I am starting to think there might be a real issue there:
To everyone saying this hasn't happen. It unfortunately did. And I came here to see if anyone else has had this happening to them before I talk to MG dealership.
Don't worry about that member every village has one and he's ours.
This forum is great at finding solutions and for the most part very helpful with a great knowledge of the car.
Have you tried to recreate the scenario to see if it repeats itself, obviously this time having the spare close by!
It would be good if you could recreate it for the dealer, a lot of MG dealers need led by the hand and pictures work better for them they struggle with words. Would save getting into a debate with the dealer.
A poor response by the RAC, does the AA have the same rule now ?
When I was an AA patrol many years ago, lockouts and flat batteries were the two most common call outs.
When I was at the vintage car show at Thirlstane Castle a couple of weeks ago I put my bag with the key in it into the boot and shut the boot, then thought, OMG what have I done! I knew this lockout thing was a possibility, and I actually did it with my previous car, a Golf, though with an ordinary key not one of these smart things that the car can sense. I was lucky, I immediately tried to re-open the boot and it opened normally. Either the car wasn't locked, or the bag was in a position where the car could sense it, I'm not sure.
This is another reason for my habit of keeping the key inside my bra. It's always there and it's not leaving my person during the day. It's not absolutely foolproof, mind you...
Also, if the key fob battery is getting to the end of its life and cannot transmit over the distance required , especially when surrounded by hand bag paraphernalia, so the various aerials in the car don't get the signal. A hard earned lesson for one ( or three ) we should not ignore.
But does that explain the automatic locking?
I like this low battery possibility, ordinarily you can't lock the keys in the boot, but if the boot was opened alone (without unlocking the car doors), it would automatically re-lock when closed, and if the key fob battery was low, or the signal shielded, it would not be able to prevent the auto re-locking.
That can happen in the scenario of the whole car being locked but just the boot being opened.
Nope. If the car is locked, the boot can't be opened if the key isn't in the range of the car. If the car is locked and the key IS in range, the boot can be opened. However, if the key is then placed in the boot and the tailgate closed, the tailgate will immediately and physically pop back open because the key is inside the car. You can't lock the key inside any part of the car, actually an excellent system.
The key must be in the car to drive so there must be something special if, as you say, the boot will pop open if the key inside the car. (Edit: I assume you mean it will still pop up when the handle is pressed?)
Really, it is important to have reasonable access to the spare keyfob (regularly tested) and the app (on a personal or friend's phone with remembered login credentials).
I’ve just discovered lately that I can lock and unlock my Berlingo with the app on my phone.
I also sat up after a night’s sleep in the back and hit one of the three switches on the ceiling which control the rear passenger lights. One of the switches appeared to unlock the doors and I meant to get back to it to check but forgot about it until now.
No, the handle doesn't need to be pressed. Simply close the tailgate while the car is in 'locked' mode (wing mirrors retracted on the Xpower for example) while the key is in the car and the tailgate will pop open by itself without being touched. It's to remind you that the key is still in the car and to remove it.
    Votes: 1,050 77.8%
    Votes: 204 15.1%
