Paul V Smith
My MG4 Trophy’s heating isn’t heating up?
It just pushes out cold air.
Mine needs to be set at 25 or 26 to get warm. Dealer is investigating. I have seen many reports of similar.My MG4 Trophy’s heating isn’t heating up?
Was set to 29c medium fanWhat HVAC settings have you set? (Temperature / fan speed)
If I assume that you mean that the blower fan operates but you can’t get any heat. There seems to be an increasing number of posts on this topic, so I’m guessing that there may be a fault on some cars, where even on full max temperature no heat is produced.My MG4 Trophy’s heating isn’t heating up?
A/C just means Air Conditioning - it doesn't (or shouldn't) mean Air Cooling.I had the same problem with my Trophy long range yesterday. +3 outside but temperature was at 28 to get any kind of warmth from the vents. A/C on too as I find if I don’t the car mists up quickly. Maybe a/c cancels out the heater.
I think I now know why. I was in ECO driving and ECO heating modes. I switched these off and got heating straight away. This of course is crazy, crazy you can’t have ECO on to save money, but you can’t have a nice warm cabin. Hopefully new updates on software will over come this.
Very useful tip!There is an option to stop the heating being affected by eco mode. Press the cog and turn off "follow eco drive mode"
ThanksVery useful tip!
You don't save much range in ECO - not enough to sacrifice heat unless you're desperately low on range.I think I now know why. I was in ECO driving and ECO heating modes. I switched these off and got heating straight away. This of course is crazy, crazy you can’t have ECO on to save money, but you can’t have a nice warm cabin. Hopefully new updates on software will over come this.
It was the heater ECO setting I switched off. Works now when driving in full driving Eco mode, problem solved.You don't save much range in ECO - not enough to sacrifice heat unless you're desperately low on range.
Is the ECO button off on the heating screen?Ok so my Trophy has been fine since I owned it for heating but just now it will only blow out cold air no matter what I change.
AbsolutelyIs the ECO button off on the heating screen?
