Coulomb
Moderator
- Apr 24, 2021
- Solutions
- 1
- Brisbane, Australia (ZS EV Mk1, MG4 ER 77kWh)
- MG4 (2022-2025)
Short answer: usually expect much lower losses when DC charging.My question is: are there comparable losses when charging the battery using DC?
Longer answer: When AC charging, the charger is in the car, after what you've paid for. With DC, the conversion losses are paid for by the provider; they charge you based on the energy provided, perhaps with a small loss in the cable, but even that can be measured. There will be small losses in the car's wiring, but that's very small compared to tens of kilowatts of DC charge power.
There is also power used for things other than the battery, like pumps, computers, but also potentially air conditioning, battery heating, radio, lights etc. Depending on how you look at it, these are losses or legitimate loads, though the 12V devices will have DC-DC losses. In a Tesla, some of those losses could be scavenged into heating the cabin, further complicating things. But again, even if you call these losses, they will be under 2kW, and therefore small unless you are right near the end of the charge, when they could approach 10% in the worst case. Usually, they will total about 500W, which is 1% of a typical 50kW charge rate. Wiring losses would be of a similar magnitude.
