Macadoodle
- Oct 20, 2022
- Location
- Scottish Highlands
- MG4 SE SR
I think you're correct.Is possible but still there are cars leaking transmission fluid despite this lower level. For those cars there must be another cause.
My 1.5 meter tube with the aluminium chamber on the end looked promising at first, checked it after around 110 miles including some 4 lane 80mph blasts and .......... it was leaking like hell
The full length of tubing had trapped oil in the low spots, the chamber had overflowed, the foam I had fixed to the end was saturated in oil.
Drained the box and there was 700ml left in there, I had filled to around 850ml.
This gearbox seems to act like an oil pump in action, the alloy chamber is situated just under the rear hatch inside the bumper, so much higher than the top of the box, and it still managed to fill that fuel filter housing and push through the foam, dumping 150ml of oil. Unbelievable. No wonder MG's silly little revised breather doesn't work !
Sooo, today I threw the last dice. Blanked off the factory breather hole and fitted an adapter in the fill hole in the side of the box, well above the left CV joint.
Fitted the same hose on that after I cleaned it of oil and filled the box with 850ml yet again ( I now probably have the freshest gear oil in the country )
I've only done around 50 miles so far but I think I might be on to something. There's NO oil in the pipe so far, it doesn't seem able to push it up the initial few inches towards the underside of the boot floor far less up behind the back bumper.
Maybe I've actually lanced the boil at last and the pressure is gone ?
Will see how she blows over the weekend
