MG4 Software Update Thread
I have r40 but the same problem with digital key doesn't turn on car. Message: nobody key found. Which software i need to control?
R40 is old. Which is the new to download? Thank you ;)
Standard with R40 and everything else up to date; Digital Key works flawlessly.
Hi guys, my car was on first service and some updates were installed. Could you please say me how to check whether SC077 was installed as well or not?
If i understand correct, SC077 is global company around the world, right? if there some official info about SC077 somewhere on SAIC\MG sites?
"SC" (Service Campaign) is an instruction to dealers to "Do this when you next have the car in your workshop", so it should've been done.
The intended result is that it makes the lane keeping slightly less agressive.
Fully updated car with SIPS is the first prerequisite. After that, just unlock the car and click on keyless start in the app before you sit inside the car.
Tbox problem version?
Anyone had any issues since SC077? Mine went in recently and had it and now shows LKA and rear collision assist errors :|
Yes. I still doesn't work as it should. It cannot properly distinguish between dashed and solid line even if the markers are completely new. As a result, it intervenes when it should not.
Also, with the indicator on and going back to the lane after passing a truck, the system still beeps and tries to intervene. Even 6 second after passing it beeps. This issue disappears if I disable the two lka modes that apply steering intervention.
SCO77 for me is nothing else but making the interventions even more modest compared to the changes they introduced in 2024. But the systems makes more errors than before.
Needless to say, I have had it with the car. My lawyer can sort it out now.
My Trophy will beep (but not try to steer) when going back to a lane after overtaking if I pull in quite soon after the overtake while the blind spot warning is active. If the blind spot warning is not active then I get no beeps.
    Votes: 1,069 77.7%
    Votes: 208 15.1%
    Votes: 99 7.2%
