MG4 Software Update Thread
Doesn't work on the SE SR - no PIN entry option ever pops up
Nobody knows the access code (if you can get it to work)
And it's been posted several times already (in this thread too) ;)
To be honest, it is a probably a good thing that we can’t access it. Very easy to break the car that way.
Just noticed this morning that the MG iSmart Android app has an update.
It wasn't there last night, so it must have just dropped this morning. :)
(As per usual - check in the Play / App store rather than in the iSMART app for the update)
Edit: version is now 1.1.9.
It allows text entry for your nickname now (rather than just a numeric keypad)
SMS code for adding phone number still doesn't work (although I suspect that's a server issue rather than an app issue)
No other obvious changes - at least with respect to my SE SR - don't know if Trophy models will see anything else
I hope they've put the driver's seat on the correct side :ROFLMAO:
Not yet ?
Wonder if there is a fix to the plugged in not charging preheat, need to wait until next charge to be able to test.
EDIT: probably not thinking about it as more likely a module in the car that needs an update to fix this.
With android version 1.1.9 the shared Digital Key functionality is broken. There is no Digital Key section in the recipient's app under My Profile.
Downgraded to version 1.1.8 to make it work again.
??? My digital key is there ?‍♂️
Edit: sorry, I note you say Shared DK ... I've never tried sharing mine.
D'oh. Still can't record my mobile phone number in the app as it tells you to enter a verification code - which it never sends :mad:
EDIT: No, hold on I think my mobile number is already registered. I just noticed a tiny notice at the bottom of the screen saying as much. It's just that the mobile number doesn't get displayed for some reason.
Ditto, as I mentioned up-thread. ☝️ :)
I think the problem is simply that, certainly in my case, at some point or other it has registered the mobile number and further attempts to do so are ignored. Because the mobile number isn't displayed on the form like the other details it gives the impression the mobile number isn't registered.
What I have discovered is that it seems critical to enter the actual mobile number with no leading zero:
If I go into the app now and attempt to enter my mobile number with a leading zero, I get the "Sending" message, but nothing happens.
If, however, I enter the mobile number with no leading zero, then I get the message "The mobile number is registered".
Go figure o_O
    Votes: 1,053 77.8%
    Votes: 205 15.2%
