JDMB
- May 6, 2023
- Surrey, UK
- MG4
Ooh, that does seem a bit much..
Definitely no damp anywhere?
Under the boot floor (someone mentioned leaky tailgate seals last weeks)
That could be for aerodynamics.
AC will dramatically reduce fogging because it dehumidifies the air, however, you shouldn't need AC in summer so if there is excessive fogging with the fan on and AC off, it suggests damp may be getting in somewhere.
What I’ve noticed in mine is that while the rubber seals are good with no obvious leaking, within the frame of the door there is an awful lot of water pooling, so much so that when the door is opened a lot comes out (we’ve had some quite heavy rain in the past week).
This happens on every door and I think this is down to the design rather than something failing, although is it a failing if this much rain can get around the door frame, so I wonder if this is contributing to the misting?
The car is very well sound insulated too, so again maybe a contributing factor?
