MG4 Trophy map update – BEWARE
After R46 you should download the maps from here https://iov-mapmg.soimt.com/#/downloadMap
Some files are slightly different and maybe it failed the last signature check. However if everything is working, it's fine..
Thanks for the info. I do wonder which to select and why.
Why one site and not the other? MG EU seems the right place, the title of the download "Map Update 2023 Q4 - Luxury Edition" is exact in my case.
Do you mean the other site is for other MG4 variants (UK, standard, etc)?
What about the alternative? what is iov-mapmg.soimt.com , how were you referred to this one (the other seems obvious and accurate for my case)
I stress once again that I very much appreciate your contribution and your effort you give
You do not have to sit in the car. I even closed the car
"Closed"? meaning closed the door or locked the car?
I got a message on infotainment screen, just before confirming to start, to keep the car in READY mode during update. So I got cold feet and aborted.
Pretty sure that means don't lock the car right? So if I do leave the car, it should be somewhere where I don't have to lock, I assume? - but the car locks itself automatically in a few seconds ... unless I leave a key in?
Locked. I had no patience to sit out the whole procedure.
Aaarghhh!!
I started to update my maps. I was warned clearly, to keep the car parked in READY mode.
After a couple confirmation messages, the final two system interactions was (something like) "upadating map resources" and then after 1-2mins "writing map files", after which a progress bar started in another couple of minutes.
That's when I made a mistake!! I opened my door... of course the car left READY mode and the process stopped!
Now the infotainment system is stuck with a warning popup window "updating map resources" and I cannot operate anything from it. I tried locking and unlocking to restart the car, no good.
Edit: after leaving the car for about an hour, I re-entered and this time the car "woke-up" from a deeper sleep (when the image of the car with the halo as it loads). This time the infotainment was ok. Restarted the loading and this time I waited in the car, until it finished.
Message when I started the Nav first time was "this map data is not correct for your car" and did not start. On the second attempt, the Nav loaded up. Now I have data from 2023Q4. Wish it were newer...
M4 Luxury Long Range, infotainment r59, usb stick formatted NTFS, time: 30'
Take a book, play radio, read magazine... take a nap, but don't open the door.
I cannot download maps from here:
Nothing happens when clicking next with my VIN entered and ignoring the fingerprint upload.
Happens using Edge and Chrome browsers.
But I get the option to download from here:
So my VIN is recognised and correct.
On R63 in the UK. Haven't tried actually downloading yet and therefore updating the car as I'm not sure which maps update package I should be using.
Is there a definitive guide to updating the maps for UK cars?
From both link, map datas were supposed to be the same.
Why you don't download files from "mgmotor.eu" ?
I send you my link from the first link, available for 5 days
I've just tried the https://iov-mapmg.soimt.com/#/downloadMap link (using Firefox) and only got a small spinning 'cog' and then nothing. I have previously got the map from it though (23Q4).
Just trying the link from the user manuals (which I have also used before 22Q2) and I'll let you know what version it is.
The map is still 23Q4
Do you really think you will get an updated version within 18 months? Forget it.
I've got a MG4 XPower.
When I enter my VIN in web page https://iov-mapmg.soimt.com/#/downloadMap and click on Next button, the page displays a red error message at the top: "Please confirm whether your vehicle is equipped with navigation and if the features are activated. Thank you"
(tested on Firefox and Chrome)
Is there a bug on server?
is the Xpower incompatible with this page?
Managed to download from https://iov-mapmg.soimt.com/#/downloadMap yesterday. Assume the server is intermittent.
However I am getting a MD5 checksum error when attempting to update in the car.
Whole process of downloading, unzipping and copying to a USB stick took over 5 hours for me so I’m giving up. For now.
Have you tried this...?
If you're on an earlier version of the infotainment system, there are two files on the USB that you need to delete before starting the update:
VN.txt and File_verification
If you delete those from the root of the USB and try it again that may resolve it for you.
Wouldn't work using the old method as get an error, currently trying to download using the VIN verification portal as on R59.
It's taking a long time - currently half way through and its been running for nearly 12 hours, 17.6GB file and only coming down at 300kB/s which is terrible.
Try this official link - User manuals
The first quarter of 2025 is done but MG still doesn't provide the fresh map update. It's still 2023 Q4!
2023 year, Carl! 2023 year!
Dear MG, when you are going to provide us the fresh map update?
    Votes: 1,014 77.9%
    Votes: 191 14.7%
    Votes: 96 7.4%
