ECourts
My second attempt failed with the same messageDid you manage to install the new map?
Back to the drawing board.
Same result in my Trophy (v1) R46.
Did both of you also get a screen with select usb source, showing three options no map data,Same result in my Trophy (v1) R46.
Done with a USB hard drive (much faster to extract the .zip file)
Will have to compare to the old maps folder to see what's the difference...
After waiting a couple of minutes watching the USB stick flashing, the "map data" option lit up, pre-checked. The others remained grey. As the USB stick had stopped flashing I presumed the system was no longer reviewing content so hit "OK". The VN file error came up immediately. Happened twice now with different downloads and different unpacking software.Did both of you also get a screen with select usb source, showing three options no map data,
no speech data,
no electronic manual on USB?
below the three there is a cancel button and an ok button
Could it be the Luxury map update does not work for trophy and xpower?After waiting a couple of minutes watching the USB stick flashing, the "map data" option lit up, pre-checked. The others remained grey. As the USB stick had stopped flashing I presumed the system was no longer reviewing content so hit "OK". The VN file error came up immediately. Happened twice now with different downloads and different unpacking software.
It doesDoes the UK Trophy etc. have EU maps on it as standard? (I note that the download file name suggests it is for EU mapping).
Could be, but I used the download link provided after entering my VIN, so I'd expect it to be correct.Could it be the Luxury map update does not work for trophy and xpower?
Yours is a Trophy LR. I expect them to be compatible with Luxury models. But sofar, I did not see anyone installing it on an ER or X-power. Unless I missed it.Just updated mine to 2023 yesterday.
I got the files off the MG EU site, entering my VIN number in the process.
First it took about 2 hours to download a failed download on Friday, then about 3 hours to successfully download again yesterday.
It took me about 4 hours to unzip the files directly to a 32Gb memory stick, the files are 23Gb.
Put it in the car, selected update and waited 3 minutes for it to recognise the Map files and 27 minutes to update.
Apart from the first failed download of the files, everything went as planned, it didn't ask for the VN file or anything when updating.
I think it would also be helpful to know the content of the text files in the "maps" directory ("file_verification" and "Version.txt“)Same issue here with the VN error and I have mg4 EU luxury spec 2022
@Kithmo could you clarify
I'm on 6.2.60.1.45160 with currently maps 22Q2 202208040318
- What's the version number reported in the zip
- what os are you using and what software did you use for the extraction
- how was the usb stick formatted
- the current Navi software version installed on your car (you can see in the navi settings, about page)
Same for me with Trophy extendedTime to collate version info for failed and working updates? My update fails with the VN file error.
Mine versions are:
Infotainment = 1300R46
Nav = 6.2.60.1.45160
