kin
I agree, software is the main issue with most cars nowadays.Most manufacturers do this now, but not all, especially with software. It is a shame but seems to be becoming the norm.
They've always done it, ever since cars were first mass produced.Most manufacturers do this now, but not all, especially with software. It is a shame but seems to be becoming the norm.
This is really helpful, thanks. Yes, others have reported loose bolts, which are inexcusable. I wonder though if they are loosening due to the poor design of the tray.I just put mine on ramps to have a better look, it looks like the tray has distorted post production. In that if you push up on it it does go flat, but wont stay due to the warping of the untertray. The undertray is quite flimsy, with no support / strength ribs (which is normal on combustion engine undertrays). So in my humble opinion, the part which the rear under tray attaches to (its touching it, if you push it flat) gets hot. The other thing that I noticed was that the 4 x 10mm hex bolts (with 25mm washers on), were quite loose (just over hand tight) - which didn't seem right - attached is a picture taken inside the undertray from the left rear wheel towards the right front, yellow circled is the offending (in my opinion) heat source, causing the distortion??
I wondered if it was heat related yesterday. My gap seemed a bit smaller having sat on the drive overnight. But it was also refitted by the dealer I went to when I was away (the dealer that at the time thought it was normal)I just put mine on ramps to have a better look, it looks like the tray has distorted post production. In that if you push up on it it does go flat, but wont stay due to the warping of the untertray. The undertray is quite flimsy, with no support / strength ribs (which is normal on combustion engine undertrays). So in my humble opinion, the part which the rear under tray attaches to (its touching it, if you push it flat) gets hot. The other thing that I noticed was that the 4 x 10mm hex bolts (with 25mm washers on), were quite loose (just over hand tight) - which didn't seem right - attached is a picture taken inside the undertray from the left rear wheel towards the right front, yellow circled is the offending (in my opinion) heat source, causing the distortion??
@jamesc83 not yet! (pretty hectic for the next few weeks!) - I just wanted to see if mine was leaking (nothing yet), and what were the implications of a warped undertray - attached is the undertray off my VW - which is contoured, strengthened and has some sound (heat?) proofing material on the underside, my feeling is that MG will have to do a bit of a redesign on this element as the current flat / flimsy one isn’t up to standard.@Tig170 are you booked in for it to be looked at and then referred to MG. Just curious being same dealer ?
Yes you’re probably right, fair enough I’ll let you know what they say to me when I go in.@jamesc83 not yet! (pretty hectic for the next few weeks!) - I just wanted to see if mine was leaking (nothing yet), and what were the implications of a warped undertray - attached is the undertray off my VW - which is contoured, strengthened and has some sound (heat?) proofing material on the underside, my feeling is that MG will have to do a bit of a redesign on this element as the current flat / flimsy one isn’t up to standard.
I am thinking along the same lines to be honest.I wonder though if they are loosening due to the poor design of the tray.
Some clever person might be able to overdub in english? That would be very interesting!seems very interesting wish I could understand Spanish.
Some interesting auto-translation (potato?) ? but generally good enough to understand what's being said.
- Click "Watch on Youtube"
 - Click on closed captions (Box with lines & dots lower right)
 - Click on settings (cog)
 - Click on "Subtitles/CC" and select "Auto Translate"
 - Select "English"
 - Watch subtitled video
Lovely- I once had a superb wee 850 minivan which became much more superber when an eleven hundred power plant was added.My 1st car was a 1963 classic tartan red ( white roof ) Mini, fitted with an engine transplanted from an Austin 1100.
I had not even passed my driving test at this point.
It was one of the nine classic Mini's I once owned over the years.
What type of notifications?Mine being worked on at the moment, my mobile is pinging away with notifications!
Probably. Mines never sent me push notifications yet. Guess that’s probably a good thing thoughI imagine notifications from the iSmart app.![]()
