jeegnesh
- Apr 4, 2024
- Bucks
- MG4 (2022-2025)
Hiya
Got my MG4 on Monday and really enjoying so far, few pain points but learning.
Current biggest concern is the charging, I had a leaf with the exact same setup and that worked as it should, but now with the MG4 in the picture having a problem.
Basically my Zappi charger is set to Eco++ which means when my solar is in excess by 1.4kW the charger will fire and car will charge. This kicks off fine, on days with cloud cover etc anytime it drops below 1.4kW the charge stops and then should restart when above 1.4kW. What I have noticed is that when this happens the MG4 on the stop charge is report the battery is full and so it will not accept further charge -- which is totally wrong the car is at 44%.
If I unplug and plug the charger then it will kick off on excess and then at some later point when it has maybe stopped and started it again says the car is full, so no further restarts.
Is anyone else having this issue with Zappi or solar excess charging?
