Jester27
- Apr 8, 2021
- Location
- Wakefield, UK
- Not an MG
Afternoon all,
I recently ordered some mudflaps for my MG4 from AliExpress.
£22.21 18%OFF | For MG4 Mulan 2023 MG 4 2022 Mud Flaps Splash Guard Mudguards MudFlaps Front Rear Fender Auto Styline Car Accessories
a.aliexpress.com
£26 including delivery.
Ordered on the 12th from China
Arrived today 26th.
Quicker than I expected.
Anyway, they're on..
Relatively easy to fit, they use existing fittings, so no drilling etc. though they are a little fiddly with space restrictions unless you were to take the wheels off.
Which isn't necessary.
Decent bit of kit, all 4 mudflaps, decent fit to the moulding of the cars shape.
Even came with spare screws (which I didn't need)
And also a small screwdriver tool which helps with the tight spaces.
Also had a seat back hanger thrown in as a gift.
Anyway, on to the fitting.. it comes with simple instructions to aid fitting, not that they're really needed.
One to watch out for is the upper screws that need to be removed, they're not screws but button fittings, they can be lifted with a flat blade screwdriver.
I reused these again in the same hole fitting.
It's then a simple case of lining up the correct mudflap and putting the screws back in to the existing holes and tightening up.
Then work your way around the other wheels and you're done.
For the money you can't go wrong, hopefully it might keep a bit of the muck off the wide sills too.
Mg 4 Schmutz fänger für mg Schlamms chutz & Spritz schutz & Zubehör mit kostenlosem Versand auf ali express
Smarter Shopping, Better Living! Aliexpress.com
Arrived today 26th.
