FallFromGrace
- May 28, 2024
- Cambridgeshire
- MG5
Thanks for this. As I'm daft, which rear plate do you select from the drop down menu?
Jaguar XJ v2 (530mm x 150mm)Thanks for this. As I'm daft, which rear plate do you select from the drop down menu?
You could just use sticky pads it will probably come with.Thank you so much
Edit - another stupid question......how do you mark up the newer bigger plate, to allow for the screw holes (all four of them)
As gomev said, I used sticky pads for the lower half. The Chinese mountings protrude slightly so the pads take up the excess and allow for a cleaner fitThank you so much
A warning for those traveling through France - apparently they take a dim view of number plates not attached with screws, weird.You could just use sticky pads it will probably come with.![]()
Mine are secured with 2 screws like a normal UK plate would plus sticky pads. The 2 screws alone would be fine but being an oversized plate, the pads add the extra supportA warning for those traveling through France - apparently they take a dim view of number plates not attached with screws, weird.
Not if the adhesive pads cover the holesIf you don't put screws in the bottom holes, is there any chance that water could get into the holes?
I'm struggling to find a 457x140. Could you let me know who supplied them, please?The optimum solution (IMHO) to the plate situation is to source plates close to the Chinese size.
This size also fits the front plinth perfectly.
457mm x 140mm is what you want.
You can't have any green strip or country ID on the above size though, so if you want that, you'll have to go with 520mm x 140mm, but then you're back to banging up against the rear badging if properly centred and you've not de-badged.
View attachment 36898View attachment 36899
If I recall, it was proplates.co.ukI'm struggling to find a 457x140. Could you let me know who supplied them, please?
I did, and received this reply today. 'The 457 plate we do is 457x111. I'm afraid we don't do the size you want.'If I recall, it was proplates.co.uk
Their online configuration doesn't offer this width, just 140mm deep at the slightly wider standard width, but if you call and tell them what you want, they'll do that size for you.
I got mine from the site below, It may require getting in touch to give dimensions you want but they did mine to the size I asked for.I'm struggling to find a 457x140. Could you let me know who supplied them, please?
officialplates.co.uk
