Radio module replacement
Could somebody explain what is happening here with the radio module? This cannot be coincidence that numerous persons are having to deal with this issue.
I have now reset it 2x but now it freezes again .. could someone also send me the file? and would like some kind of manual please??
U moet de usb formatteren naar fat32 of exfat. Vervolgens ga je naar de engineering mode en selecteer je de update dab.
Can you please send me the file?
Hi guys my long range mg5 went into dealers today as it was showing radio module initialising when they phoned me up they confirmed that it needed a replacementhol module they said they would order the part but could not give me an eta. Does anyone who’s had this done know the waiting time for the part.
Don't know if really valid, but my MG HS Phev has the central LCD unit taken out to be sent back to MG for repair!! However, having been away for a week got call today advising that due to backlog! unit will not be back until mid/late September. Contacted MG UK (eventually) and was told to approach dealer for a courtesy car. Picking up replacement on Monday. My reason was that whilst my MG still working, I have no control over heating/cooling, cruise control, limiter. Also, the emergency electronic braking systems now not working.
You should format the usb to fat32 or exfat. Next you enter to engineering mode and you select the update dab .
He don't start what do i wrong?
That is on de usb stick
Anyone having issues installing? it just keeps telling "start update dab".
Just with the single bin file on the stick...
How did you fix this? I have the same issue
Hallo, Benutti, ik denk dat ik je probleem heb, omdat ik de DAB-patch uit de auto had verwijderd. Dus als je de patch met mij deelt, zal ik proberen hem te installeren en dan zal ik je over mijn resultaten schrijven. Bedankt in advies
How did you fix it? I have the same issue he doesn't start the update
Yes already tried..same it looks like he didnt read de usb...i put the usb in the left (Android auto ) usb port. Led is on ..but nothing happend. No error or info only the White bar ...
Maybe you have a hardware issue not software . Did you contact you dealer ?
Mayby beacause my radio is blocked 'radio module installation error' it didnt works?? I tried tomorrow first the 12 v batt negative loosse.. en than i tried the update again. Thank you for al your support ?
