Robin666
- Jul 3, 2023
- Southampton
- MG4
Haha it is quite small isn’t it ?
Same, plus an application of Rain-X.I have never yet needed to clean the back window of mine outside a full wash of the car.
I haven't even needed that.Same, plus an application of Rain-X.![]()
That's what the door mirrors and reversing camera are for.I guess you never have to reverse then?
Better than nothing I thinkYep, right behind the third neckrest. ?
Just had an unscientific measure with a ruler on Robin666's photo and no you can't fit a longer wiper.Could you put a longer blade on the tiny rear wiper to make it more effective? Looks like there's loads of space before you'd have to worry about it fouling on anything
At first I though it might be the sun on the lens but it does it when the sun is on the other side of the house too. No problem anywhere else just reversing off my drive.That's odd, I've never noticed an effect like that.
My rear sensors go nuts when I'm reversing off my drive (I live in a cul-de-sac) even though there's nothing behind me. I suspect they're picking up the hedge which is a good 3" clear of the rear sides of the car.
If I didn't have the cameras I would be worried about running over someone or something due to me ignoring the false indication the sensors are giving.
That's what's a mystery to me, it's the rear segment that's showing on the display and a red warning when I ignore it. It's as if I've just ran over somebody.Actually, having re-read your post, yes, if something is only three inches from the side of the car, the SE's side parking sensors will definitely bleep. At the same time the side segments on the alert screen will display a proximity warning.
This happens when I'm reversing into the garage. Both side warnings go off as the rear of the car goes through the doors, but the central warnings are not activated. Then after I pass through the door the right-hand warning goes off, but the left-hand warning stays on because the garage wall is close. As I approach the boxes at the back of the garage the central warnings become activated and tell me when to stop.
If you're reversing and you know there's something to the side of you, you can ignore the side warnings so long as your mirrors tell you you're not slanting into whatever it is. But at least it's telling you there's something there.
It's as if there is something directly behind the car, but there's nothing on the camera and it only happens in this scenario, nowhere else.I don't really understand what you're saying, as I have an SE rather than a Trophy. I only get the two central segments lighting up if there's something actually behind the car. It's possible you have a malfunctioning system, but not knowing how the Trophy's system is meant to operate I don't really know.
