Solar Charging
Bazzer44
Leeds
Just got solar panels and have Rolec home charger
Any one else got advice on this combination with 2020 ZS EV and Solar Charging?
I have an off grid setup in my shed. Currently 2.8kw of panels, 6000w inverter but only about 4-5kwh of usable battery capacity.
As it stands, I can put a "bit" of power into the car @ 6-8amps when there is good sun. I really need more panels and battery capacity to make it viable.
Thanks for that
I have 4kw ,11kw battery ,need to learn it's working , will get there eventually
I have 4kW of PV with an 8kWh battery, and a variable current granny lead. I put it on 6 Amps to start with to share the solar with the battery and the car, and gradually increase the amps as the sun gets higher in the sky. Yesterday I put 9% back in the battery purely from solar. This morning as of 09:30, 1.4kW is going to the car and 100W into the house battery. When the house battery starts to get more than the car, I up the amps. :)
I installed an adjustable current monitering device that switches on a contactor when the solar panels reach 2.2kw output (4kw fitted) at that point it turns off the 1.5 kw immersion heater which is also current controlled.
I used to be running about switching the granny lead on and off when clouds came and went at a fraction of the price of a Zappi et al, now it is completely automatic.
I reckon I will get 40 to 50 free mIles today and I have now got (or will have on Tuesday) a 61kw home battery.
Very happy chappy
Self-Powered Sensor Switch 40-400Hz AC Current Adjustable Flameproof IP30
Models: BEMG30NO Normally. you will need a contactorOpen
£13.83
Available on Ebay, there there is a cheaper version on ebay which looks similar but is rubbish and this one is also din rail mounted.
You will need a contactor or relay to switch the load as the sensor switch will only handle up to 0.5 amps.
So for about £25 and some cable and a socket, et voila!
