andrewhs
- May 20, 2023
- south scotland
- MG4
Does the battery equalisation happen automatically or do i need to do something ?
As others have said leave it once at 100% then monitor your IHD to see when the balance has finished.Does the battery equalisation happen automatically or do i need to do something ?
I’ve recently learned every few months you are meant to go below 10% apparently on SE anyway...
Not very, I would guess, if it's beneficial at all. It may help if you regularly go down to low SoC, but then you're already doing it.Wonder how important that process is ?
Wow. My ZS EV takes about 350W when equalising, and sometimes kilowatts (MG logo lights not "breathing", on solid). I suppose that 20W is possible, but it seems very low to me.The SE SR will typically balance charge at about .02kW (20W) for about 30 minutes before it tells the wall box/granny lead that the charge is complete.
Where did you learn about every few months going down below 10% then slow charging, Gazza? You would think they would have to flag such stuff up to us on purchase or in the manual!Yep just leave the car to do its thing. When I got my SE the balancing sessions were quite lengthy (my charger displays a graph and there would be several spikes so 7kW charging down to near nothing then a few spikes up to a kW or so). Not sure if it’s colder weather weather, more use or changing to keeping charging to 5hr window but it seems to do one spike now and complete.
I’ve recently learned every few months you are meant to go below 10% apparently on SE anyway and slow charge I wonder if that’s for calibration. Below about 20% got some weird issues of limited power 28% then fine again - maybe the cold. Wonder how important that process is ?
It is in the manual ??Where did you learn about every few months going down below 10% then slow charging, Gazza? You would think they would have to flag such stuff up to us on purchase or in the manual!
Below 10% SoC is where the voltage curve takes a deep dive and the BMS calibrates against it.Not very, I would guess, if it's beneficial at all. It may help if you regularly go down to low SoC, but then you're already doing it.
thanks, I'll have to reread it!It is in the manual ??![]()
Yes, NMC battery can draw anything from a few hundred watts to a few kilowatts when balancing.
Some alternative acronyms:
LFP = Likes Full Please! (100%)
NMC = Normally Moderate Charging (80%)
My SE … with its boot leak is more akin to …. Like a naughty word PoolThat's good! I am SO stealing that.
3kW from a granny? Highly unlikely. More like 2kW at mostI'm beginning to doubt that when charging MG4 Trophy with Zappi to 100% if the battery does actually equaliize at all. Today I charged to 100% by 5.30 am and then later I connected the granny charger which took charge starting at 3kw reducing to 0.4 kw for a further 45 minutes.
