Lane Assist Trying To Kill Me!
MG have to do a recall once a solid firmware is released. Do we have to wait for someone to get killed?
First impression? Old. Your MG needs a refreshment.
But you need to go to the hidden menu for details.
You can't determine that precisely ... AU/NZ software numbering is different to what we have over here. ;)
It would be better for AU/NZ forum members to respond re. local software version numbers. :)
That's why I said first impression and asked for going into the hidden menu. However, they added opd to the Excite, as well as an ACC and AEB update.
Consensus initially was that R05 was the max for his car. But then I read R11 in Update of an SE SR
With the UK/EU Infotainment software you can access the Engineer menu in the SE (Excite) cars by typing the following code into the car's telephone keypad:
Code:
#*#4479*#*
Maybe give that a try?
And then I realized this isn't working on the SE...aarghh. Sorry for the confusion Decrep.
But if with acc on your car is no longer dropping the speed, you got that update.
No worries, but I haven't tried ACC yet, I'll do so tomorrow.
Code:
#*#4479*#*
Thanks Siteguru,
Next question, where's the telephone keypad? Do I need phone plugged in?
I'm not sure if you need your phone connected (even just by Bluetooth). Press the telephone button on the steering wheel (or on the screen menu) then (if it appears) press the symbol to bring up the number keypad. Once there simply type in the above code - if it is accepted then after releasing the last key the screen should change to show the menu. See my 1100R33 thread for photos of the screens I found.
Press the physical Home button to return to the normal screen.
Ok I'm in version is still saying R05, but there's a lot of other numbers here, are they significant?
They are related to other firmware for systems like lka, BT etc.
We should compare it with others with an AU/NZ SE to see if they are old. Maybe take a picture?
Also tried ACC briefly, and don't like it. It started to slow down too late and too suddenly.
I would slow down earlier and smoother.
If you activate ACC you can increase the distance to reduce speed earlier with the left-right arrow button. If it is on the shortest distance (=latest update), there are two clicks more.
In addition, you might reduce regen under braking. Regen=3 may cause short, sudden speed reduction.
Thanks again NLMGSAN, yes I was in OPD mode, so that would explain the jerky slowdown. I'll have another experiment.
Here's the version pics.
Hope this helps to determine what's going on.
Cheers,
Mike
Cheers,
Mike
Mike, hide your VIN or at least partially mask it. It's the ID of your car.
Next step is to ask for other SE owners in NZ/AU to do the same so we can compare.
On the French forum they started collection this data, including updates after a service. Ideally, you could link it to complaints of owners and then see if certain changes actually lead to improvements.
OK I've deleted that pic, I'll repost it without the VIN.
I guess I should start a new thread in the Australian MG4 forum
I have had my MG4 EV for approximately 4 weeks (2,000 miles and counting!) and my lane assist is most definitely trying to kill me!
Leaving it in emergency lane assist is asking for an accident, the car reacts so violently that you can quite easily end up in a different lane, or off the road entirely.
The lane keep assist is not much better, the sensitivity of the movement the car makes is not as violent, but it has been known to start to wander into a different lane.
In my meagre opinion MG need to recall and programme (or send an update) to tone down the sharpness of the emergency lane assist!!
I have had the same experience
I was nearly killed the other day facing the same experience you had .I have refused to drive the car until MG ADMIT there is a major defect in there lane assistant management system.
    Votes: 967 77.7%
    Votes: 185 14.9%
    Votes: 93 7.5%
