Ok yes.
Looks like a common issue in cold climates so I am not going to worry about it.
yes but driving at speed gives a huge windchill factor when something is wet. 8C could probably drop to freezing.
That’s not how wind chill works. It won’t freeze something just because it’s windy. It really is only a thing for living things that perceive temperature.
That’s not how wind chill works. It won’t freeze something just because it’s windy. It really is only a thing for living things the perceive temperature.
That's because living things are moist, it's rapidly moving air evaporating water that has a cooling effect. That's how evaporative air-conditioners work, and "Coolgardie safes" , the things we had before refrigerators.
That's because living things are moist, it's rapidly moving air evaporating water that has a cooling effect. That's how evaporative air-conditioners work, and "Coolgardie safes, the things we had before refrigerators.
Cooling and phase changes have dramatically different levels of energy transfer.
It takes way more energy transfer to freeze water than it does to cool water temperature down.
e.g. dropping water temperature by 8°C is only 1/10th of the energy transfer required to change state from liquid at 0°C to ice at 0°C.
I am booked to do my 40k / 2 year service tomorrow, I just now received a text saying sorry they need to reschedule till next week as a part is not in. I rang up and asked them, it is a standard service, and what parts are they talking about, they said that the pollen filter has not come in time. Did not know this was part of the service? This is Westpoint Hillcrest Queensland.
Hi all, just hoping someone here in the oz thread has had a similar issue with charging. I’m brand new to EV’s so perhaps I’m missing something.
When I charge, whether at home or at a fast charger. I get out lock the car, wait a few seconds and unlock and plug the charger cable in followed by the power.
Pretty much every time in both home granny chargers and fast chargers it doesn’t do anything till I’ve fiddled around pulling out the charger and or locking and unlocking the car a few times.? Normally takes 3-4 goes before I get the green lights.
I’m a little concerned as I’m getting a level 2 home charger installed and it will be set up to schedule charge overnight 12-6 and I can imagine how frustrating it’s going to be waking up to find the charging never started?
Is there a specific order I need to do things, particularly with a Tesla wall charger I’ll be using with a scheduled charge overnight?
Thanks in advance for any assistance.
When I charge, whether at home or at a fast charger. I get out lock the car, wait a few seconds and unlock and plug the charger in followed by the power.
Why do you do that?
Just get out, open the charge flap and plug the charger in.
If it's a DC fast charger, activate the charge session via the associated app or tap your RFID card.
The charging will start.
If an AC charger, it will probably start automatically but if it's a commercial one you will have to start it via the app or RFID card.
Very occasionally you may have to manually start the charge session in the car. Look at the main infotainment screen on the charging panel.
If it says "start" then you can tap that and it should kick off the charging session. That's also the spot you can stop a charging session if you want to.
After charging has commenced you can lock the car and leave it.
After a while you will be confident enough to just follow the normal process and not worry that it will start ;)
My routine for granny charging is. Make sure the car is all fired up. Plug the Granny Charger in your socket. Then in your car. Then switch on at the socket, then lock the car. It then shows it's charging. Works every time, never fails.
Oh, and.
To the forum. 🙂👍
Is there a specific order I need to do things, particularly with a tesla charger I’ll be using with a scheduled charge overnight?.
I have a Tesla wall charger. It's great.
I have it configured to charge from 9pm through to 3pm the next day. 3pm to 9pm is our peak tariff time.
If you plug the car in at say 2 in the arvo it will charge for an hour, then stop and then recommence charging at 9pm.
A very good charger for the money. Recommended.
Why do you do that?
In my recent experience on charging out of home - the car would not charge if the car was still on, whether DC or AC charging, I had to get out of the car, switch it off with the key fob, unlock with the key fob, open flap door, connect charging cable and then it would charge, - it would throw up an error message on the dash EV High Voltage battery ! if I did not shut the car down completely before charging.
Why do you do that?
Thanks, perhaps I’ve still got a little range/ charge anxiety. I’ll give thst a go and see how I go.
Perhaps I’ve just been overthinking it.
When I arrive home I get out of the car, open the charge port, plug in and lock the car. That's it.
My charge station looks after the rest and is set to start charging based on settings, either to charge from excess solar PV or during free grid energy period.
That's what I do except I don't lock the car is it is in my locked garage. I don't have any software to charge from excess solar so if the battery is down and it is a sunny day I just use iSmart to start the charge a bit earlier sometimes at 20 amps & then up to 32 amps when solar energy is abundant and/or when the free grid energy period kicks in.
Ok thanks for the information, I will go to another tyre shop and see if it fits at the back - they may have only tried it in the front.
Ok so I went to a specialist tyre shop and they confirmed that the spare does fit the back wheels but not the front as the brake caliper is too big in the front, so that is a relief, I can take it with me if I have a flat (as a back up) when out bush.
You may be a bit impatient. That was my problem when I first started charging. For some reason my car has to think about it for a bit before anything starts happening. It doesn't help that the screen says, "Not Charging" for several seconds, before relays start clicking, then it says, "slow charging" and the cable socket turns green.
So just try waiting for a bit and see what happens.
I think the locking and unlocking routine, only seems to work because it just gives the system time to do it's thing. If you just patiently waited you'd have the same result.
    Votes: 1,025 77.5%
    Votes: 201 15.2%
    Votes: 96 7.3%
