Why import over 11kW unless this is during the free period.? Would it not be better to reduce the charging level of the car or battery or both so you are not importing energy & having to pay or it. If it is a good sunny day the charging would take a lot longer but if you are not planning on going anywhere that seems sensible to me before 11:00 or after 14:00..
Today my MG4 was down to about 40% & charged from 11:00 till 14:00 at about 7.1kW AC using some home battery as today is partly cloudy but drawing none from the grid & the battery will be back at 100% within a few hours. I don't have control of the software to be able to draw from the grid when it is free. Unless the temperature is mid to high 30s we leave the house open during the day. Even on those hot sticky humid days with the AC on I have still not imported any power since the system went in on 24 November.
System really sucking down the juice (@ 24.6 kW), using all available solar + free grid energy to charge home battery, the MG4 via DC charger and power the home (ducted aircon going):
The load side is 12.5kW DC charger is voltage boosted to 400vdc, so 31.25 amps
The house is consuming 3.8kW AC, converted to AC and held @ 230vac 16 amps
The input side is 13.3kW DC but as yet, voltage unknown.
The grid supply is 11.28kW AC @ 230vac @ 49 amps, supplying the house direct, the remaining 7.5kw is converted to DC at ? voltage to charge the house batteries?
T1 Terry
As mentioned...
Even though it was free, this is not a normal set up for our charging, I was just testing stuff.
It's pretty impressive being able to load up both the DC and AC sides of the system to simultaneously consume close to 25 kW.
It's not that easy to determine where exactly the DC solar power goes to. In reality you are pouring energy from a couple of sources into a big bucket and taking it out from the same bucket to power various loads.
Solar PV can directly charge either the car or battery via the DC bus but since combined battery + EV charging exceeded the solar PV output then the deficit was coming from the grid, plus of course powering the house.
If I go by the system's own accounting, it suggests the car took priority for solar PV, with the home battery using the supplemental grid energy. But it could just as easily have claimed the home battery was all solar PV and the car used some supplemental grid energy.
This is the supply and demand during that period. I didn't do it for long:
For unusual reasons (taking guests for sightseeing run in the MG4), I had a proper need to do it again today but for much longer, this time 1 hour 20 minutes. Works great.
Afternoon storms killed PV output.
I've worked out the yellow part is solar, no idea what the other colours are ....
T1 Terry
See the legend below the chart.
Above the line is supply - solar, battery discharge and grid import.
Below the line is demand - household consumption, EV chargers, battery charging and grid export.
Do you have scope to add more solar PV?
Most of the best roof real estate is taken up with a pool solar thermal heating system. We've filled the rest with what PV we could fit.
If the pool system carks it, I may add more, or at least move some from less favourable spots to the nice north facing roof space. It's not that critical when you get three hours of free grid energy every day.
Opened it in a new tab and then I could see them :rolleyes: I'm starting to wonder if the marbles are rolling at all just lately :oops:
T1 Terry
Not sure in which thread it was but there was a question a while back about the charging plugs I have.
Here are the two types of plug I have:
On the right is the CCS Type 2 DC charging plug.
The black one on the left is a regular Mennekes Type 2 plug from our ZJBeny single phase 7 kW EVSE (which is partially in view at the bottom of the photo). The 3 ports across the middle are for the neutral, earth and L1 (live). Note that the two lower ports have nothing in them - those are for 3-phase cables with L2 and L3.
Our Sigenergy single phase AC EVSE has the same plug type. These are for supplying the car with AC power, which the car's on-board charger uses.
This is the Sigenergy AC EVSE:
Side view of the CC2 Type 2 plug from my Sigenergy DC charging module:
This is the same plug type as found on DC fast charge stations and connects directly to the battery, bypassing the car's on-board charger. The power flows through the two larger ports and the DC charging system reports on the car's SOC via the MySigen app (it communicates with the car's BMS).
And this is the Sigenergy stack with the DC charging module incorporated.
The stack is against the rear wall of our garage. The DC charge module is the second module down sandwiched between the energy controller (inverter) on top and the battery modules below. The charge cable emerges from the bottom left of the stack. It's quite a thick/heavy cable and is 10m long.
The cable hanger on the side wall allows for stowing the long cable when not in use.
Our DC charge module is rated to supply up to 12.5 kW (and in use it comes close to that). It is software upgradeable to 25 kW however I have little need for that given we are on a single phase supply with 63 A breaker and only have 14.7 kW of solar PV spread across multiple azimuths.
It has multiple modes of operation and is bidirectional.
The mode I mainly use is to charge from excess solar and it does a great job of that. It can adjust the power flow faster and with more granularity than AC charge stations (which operate in 1 A increments) and it can also charge at low power levels well below 1 kW if there is not much excess solar. But the great part from my perspective about charge from solar is that all the power is handled via the DC bus leaving the inverter capacity free for the home.
Of course you can if you want use it to charge the car from the home battery and/or the grid.
It also provides V2X capability via the Sigenergy stack, it can use the car battery to power the home, export to the grid or charge the home battery. My main interest in V2X capability is for additional supply during grid outages. I don't propose to use the cars as regular supply points, we have enough home battery capacity for most regular scenarios.
I have tested V2H with both our MG4 (Essence 64 kWh NMC) and MG ZSEV (50 kWh LFP). Works fine.
I have slowly been getting back to my bike riding after a long time away from it. Not bike races like I did in the old days, just enjoyable rides. I'm too fat for racing anymore!
There's a local bike riding group I've joined and it's been great to get out and about again. After being back on the bike for about 6 months or so, yesterday I did my first 100 km ride in many years.
Starting back on the bike was all part of our plan with our house move. We are now in a home where I can just roll straight out of the shed and onto excellent cycling roads. Previously I had to drive somewhere to do a ride, it's just a hassle/barrier. Being a leg amputee just adds to the hassle as I need to fart about changing legs (I have a dedicated cycling leg) and that means more kit to carry. It's so much easier doing all that at home and just rolling out the door.
That said, I do want to travel places and do granfondos, ride challenges or visiting mates in other towns for some fun outings. I'm also keen to try some rail trails at some stage when I get a gravel bike suitable for them.
So driving places to ride is still going to be a thing, just not all the time.
With increasing fitness I'm now occasionally travelling to participate in cycle events. I went to Tumut a few weeks back for an organised event, that involved a drive to Sydney to hook up with a good mate and we took his car to Tumut from there.
When travelling by myself carrying the bike in the car is no issue, I can get the bike in the back of the car easily enough with rear seats down and the front wheel removed but for the next event my wife will be coming along as we have some couples friends doing the same. Nice long weekend away.
But I need a way to transport the bike plus have room for luggage, passengers etc. I could still get the luggage and bike in the back if I really wanted but I plan to make this a more regular thing so being able to load the bike onto a carrier seemed the way to go. Keep the interior free for luggage and people.
While I've had roof rack bike carrier on most of my previous cars, I didn't want to put them on the MG4, so this time I've decided on a tow hitch bike carrier.
In the end I went for the Kuat Sherpa 2.0. I liked the design, general features and the fact that removing it from the tow hitch is a simple operation which requires no tools. Fitted it today, some pics:
It has a release lever allowing you to tilt the rack down to have access to the tailgate:
Which opens without issue.
In this configuration there's actually enough room for me to sit on the rear lip of the car so I can swap my leg over.
Then it's easy to fold the rack up and out of the way when not used. It is key locked to the hitch. There is also a cable for locking the bikes to the carrier - it has a key lock built in. Useful for those times you need short term unsupervised security.
I'll do some local drives with it, need to test it out and check I'm doing it right but it's simple enough.
Also need to order a bike carrier number plate from Service NSW. Not legal to use these without the extra rear plate being visible from all rear angles.
The brake lights and indicators are visible with the bikes on the rack.
The rack weighs 14.5 kg, while the two bikes shelves have a load limit of ~18 kg each, perfect given the MG4 towball downforce rating (50 kg). That is fairly generous for typical lightweight road/gravel bikes and e-bikes. My two bikes combined would be 16 kg or so and I'm most likely to carry just the one.
It is a very tight fit with the handlebar of the inner bike being very close to the car's rear light shelf, it could rub - the bar tape can touch. My handlebars (44 cm) are fairly wide for a road bike, but not an MTB (I don't do MTB, not much fun in dirt/mud with my leg). In such a case you might put a wide bar bike on the outer carrier shelf.
I paid A$949 delivered to my door.
Thanks for that idea. I'd love to take the bikes behind the MG4, or behind the motorhome, maybe I can modify one of these to work with both vehicles.
My knees will not let me ride very far these days, MVA wrecked the left one and the overload wrecked the right one, so no more Sydney to 'gong bike rides for me ...... but I'd love to still be able to get around on an electric bike and the wife wants to start riding again as well.
T1 Terry
I assume you already had the tow-bar fitted?
Interested in the Number Plate legality. I am assuming that simply relocating the existing plate to the rear of the carrier is not allowed? Could you do this if illumination was also fitted in the temporary location?
Just me being curious as I am unlikely to fit a bike rack, though I will fit a tow-bar soon.
Yes, ref my post from early last year:
The tow bar fitment came with two attachments, the tow ball attachment as seen in that post above, as well as a hitch adapter for bike carrier attachments.
I removed the tow ball unit and put on the bike carrier adapter before installing the carrier.
This is the relevant NSW web page:
Other states may have different requirements.
Since the bikes and carrier are likely to be removed from the back of the car often, it would not be practical to be unscrewing and re-screwing on a full number plate. I'd consider the plate on the car to be "permanent".
A number plate light is also a requirement although I won't be driving at night with it. If I do however then it's just a case of putting a small light onto the carrier arm to shine onto the auxiliary plate.
I have now ordered my auxiliary plate.
A majority of the riders in my local group are using e-bikes.
It has really democratised cycling in groups and extended the cycling participation lifespan for many older riders as the ebikes "flatten out" rides so much. No one is left far behind because the e-bikes get up the hills so well.
Assistance (for legal ebikes) is limited to speeds up to 25 km/h, so it's no surprise many of then don't ride particularly fast on the flat terrain, but once the hills starts they get up them no issue.
I was contemplating one myself having been away from the bike for so long but I've got enough fitness back now I don't need it. When I get older it will be on my list.
I have an e-bike which I use to ride the Bay Run each morning after having taken the dogs for their morning walk.
Love it. Certainly does make the uphill bits a lot more enjoyable than the alternative :ROFLMAO:
Walking and pushing the bike you mean ..... was that why the call them push bikes?
That climb through the Royal National Park from sea level at the concrete weir after that thrilling down hill run from Waterfall stn back up to Stanwell Tops where the hang gliders are, with all the short down hills followed by an even steeper uphill, is torture on a heavy push bike, never tried it on a light weight racing bike ......
T1 Terry
Those that are in Australia I wanted to ask what version is the latest for the MPU and MCU? For a M4 Exite 51
Because after now at least 2 updates that I've requested for from the MG dealership I'm on version
MPU: SW131-29958-110R05
MCU: -125.1.3.0
I have attached a image from the car dash, because after doing a LOT of reading in here that R05 is what the Australian cars ship with, and the -125 doesn't exist AT ALL so I'm looking for some confirmations if you could please.
MCU: -125.1.3.0
What is the difference between the MPU and MCU versions that would be obvious to the user?
T1 Terry
MCU: -125.1.3.0
That's exactly what I have now, not updated since Feb 23.
Mine is going in for a service later this month, and they say they'll update the LKA thing, I'll know more after that.
    Votes: 1,076 77.8%
    Votes: 208 15.0%
    Votes: 100 7.2%
