- Jun 13, 2022
- Location
- Paignton, UK
- MG4
This is a prime example where a simple statement from MGUK would explain what is going on and avoid a lot of hassle and worry.
Agree simple thing to put out and keeps the customer up to date. Faults happens it's how the fixing and communication goes that annoys people.This is a prime example where a simple statement from MGUK would explain what is going on and avoid a lot of hassle and worry.
Is that a comment from the French Troll?Agree simple thing to put out and keeps the customer up to date. Faults happens it's how the fixing and communication goes that annoys people.
sur mon meilleur comportement aujourd'hui?
Le jour est encore jeune ?Agree simple thing to put out and keeps the customer up to date. Faults happens it's how the fixing and communication goes that annoys people.
Do you know if MG are fitting these modified breathers to all cars now?The one in the picture above is the one fitted to my car and there is a newer, longer one which is being fitted at the factory only so I was told by Tech Manager. He showed me a pile of breathers on his desk in plastic bags which were for existing cars and that was the same as mine. He then said new cars now come with a different one ?- his point was, why are they not sending the latest when the fault is logged.
Mine came with modified breather. Had it 2 months, 3k miles , no leak.Do you know if MG are fitting these modified breathers to all cars now?
They probably got a load of these made before they discovered they don't always work and are fitting them in a vain hope that it cures the leak. Eventually the penny will drop and all cars may then get modified.The one in the picture above is the one fitted to my car and there is a newer, longer one which is being fitted at the factory only so I was told by Tech Manager. He showed me a pile of breathers on his desk in plastic bags which were for existing cars and that was the same as mine. He then said new cars now come with a different one ?- his point was, why are they not sending the latest when the fault is logged.
They look almost identical, so not sure what the difference is unless as I suspect that the mark 2 may not contain a ball valve, which would eliminate pressure build up and spitting effect.
He told me that new orders were coming through with a new breather now (different to the one that is still being retrofitted) that’s all I can tell youDo you know if MG are fitting these modified breathers to all cars now?
That is the key issue.I'm betting filling that casing to the bottom of that plug hole takes 900ml of the slippery stuff.
Were there any aluminium/copper crush washers that you had to replace or was there a washer with rubber gaskets bonded to them already fixed on the drain plugsSome random ones
There were washers on both the drain & fill plugs but I just did as Macadoodle did and did it by feel & just re-used them as unfortunately any workshop info is nigh impossible to get unless you know a tech etc. atm Really can't wait until hopefully someone gets a copy & made public.Were there any aluminium/copper crush washers that you had to replace or was there a washer with rubber gaskets bonded to them already fixed on the drain plugs
Edit: I can see from one of your photos that there are aluminium crush washers. What the inner diameter and what torque did you re tigh
