BugEyed
Part of the issue is probably that the IT in cars is developed for more different platforms than PCs and that they generally have low levels of physical resources.
Me neither. I expect there will be another round of updates after not too long and hopefully there will be OTA infotainment updates starting up.I really don’t understand why the infotainment isn’t being upgraded to R30 if they’re upgrading everything else. It’s really strange.
Do you actually know all those abbreviationsMine is now returned from dealers. Work sheet states updates available, carried out and tested for BCM, BMS, FICM, FVCM, GW, IMCU, IPK, TBOX. App went nuts for a while when they were doing it.
They were generally polite but would not tell me which versions are now installed and were generally quite cagey about giving any info at all. Wouldn't even give me a copy of the work carried out until I insisted. All a bit weird.
Infotainment still showing R29.
I know two if them, Body Control Module and Battery Management System, but the rest ??Do you actually know all those abbreviations
Maybe we could have a thread that lists all these on a sticky post??
Someone posted a screenshot or a video of a service menu that listed all the modules but I can't find it.Do you actually know all those abbreviations
@AndyM Has your infotainment stopped cycling between screens and can you now get to the settings?Mine is now returned from dealers. Work sheet states updates available, carried out and tested for BCM, BMS, FICM, FVCM, GW, IMCU, IPK, TBOX. App went nuts for a while when they were doing it.
My car has started doing this afternoon on the way home from work.
It actually fixed this part itself.@AndyM Has your infotainment stopped cycling between screens and can you now get to the settings?
I know what you mean, but assuming it is similar to the ZS, it isn't a case of simply running an installer from a usb drive. The car has to be physically connected to servers in China. There is not a single update but various modules that may or may not need updating and there may be a certain order in which these should be applied.I just don't get with modern hardware and USB interfaces rather than CD's and old style serial ports how it can supposedly need to be left plugged in overnight.
Thanks @Gem10 factory reset has done the job and stopped the screen bouncing around and cycling between main and options screen.Two options that have worked for people who have had this issue.
1. Go to the radio section and select a DAB station.
2. Factory reset from settings.
Network issues, time zones, language, supporting documentation, dealer experience and competence all play a part. I'm not excusing MG but it isn't just 'plug and play'.
In my experience MG are quicker to revise their software than many manufactures but their testing may not always be as rigorous, meaning that newer versions can sometimes introduce new bugs or conflicts as well as solving others. Rushing to get the latest software release is not always for the best unless there is a significant issue with your current version of software.
No, I just don't want a warning triangle on the dash as that irritates me. Had it come without it I would have been pleased (secretly).You actually WANT the driver fatigue warning continually nagging you???
I feel your pain.Given that it isn't just the pre-production message its the driver alertness system fault I would quite like to have it working, the car in its current state is not as described and therefore not fit for purpose.
