Tesla Supercharger Issue MG5 LR
Does anyone know of any MG dealers in Central Scotland or the North of England that do the Tesla Super Charger update for a pre-facelift MG5 Long Range? I phoned Central Garage in Galashiels, but the guy on the phone was clueless, took my number and after about 10 days, he still hasn't called me back. I normally use Cleeveley to service my MG5, but they said that they couldn't do the upgrade and that it had to be done at an MG dealer. I'm not desperate, as I charge at home and seldom use public chargers. It would just be nice to be able to use Tesla Super Chargers, if I am out and about.
Frasers of Falkirk did mine eventually for free along with my third service and MOT. I bought both my ZS ev and my long range pfl 5 from them. Very good.
You're being much more "polite" about this than I would be!
If you've paid them to do a specific job for you and it's either not been done or it's not "worked" you should be demanding either that they redo it, properly this time, or give you a full refund.
Further debacle with the dealer today.
I finally received a call back. Their service manager has apparently been in touch with MG who confirmed only the MG4 supports the Tesla Superchargers and no update is available for the 5.
Clearly that's incorrect.
And, what update they applied when they charged me £40 is anyone's guess. Arguing the case didn't get me anywhere so there no chance of getting the update done here.
In addition, they haven't updated the software on the infotainment system with the 2nd year service as I'm still on the version that came with the car.
Budgen Telford is a dealer to avoid if you need the update in the West Midlands area! Brindley Wolverhampton knew fully about the update but the cost of the service was £140 MORE in addition to the update cost. Around my area, there isn't a great service network.
I was thinking about an S5 once this car's finance was up, but I think I'll be looking at an Omoda E5 instead as I can't get the support required within a reasonable distance from me.
The lack of, or how difficult dealers and MG make support is the reason that owners will switch brands away from MG. Combining poor dealer knowledge with MG's customer service model can make for a harrowing experience. Unfortunately. Personally my local dealer was excellent but if they ever had to contact MG it turned into a drama.
Imagine if the customer service was as good as the vehicles generally are.
Persistence paid off for the refund of the £40 paid. They've agreed to refund me.
I asked what update they'd applied. They said the correct Tesla update was applied but it doesn't work yet. I have no idea what that means.
Since the infotainment software wasn't updated, I can only assume that no updates were done to the car at all.
Regardless, money back and no Tesla compatibility. I'll leave it that way going forwards as it isn't worth the hassle.
That’s an excellent idea, I did wonder if it’s possible, love to hear if others have done this already to the MG5?
You can do the updates yourself for circa £135
SAIC RMI access is c.£16 for 24hrs
Just need a windows laptop.
Benefit is that you can do full updates across the board, including infotainment, and for as a long as they are available, with no further investment beyond periodical access costs.
Full guide is here (MG4, but everything’s identical) Diagnostic VDI, VNCI, MDI with MG4
I'd be worried about bricking something.
Also, it wouldn't surprise me if my car has a weird software version as it was one of the late preface lift models that started throwing check HV battery errors and had to have some software update developed to fix it, i'd not want to cause that issue to resurface.
Well, I can finally confirm the update did the trick on my 22 plate MG5.
We had a trip to Seahouses today, and I did a slight detour to Adderstone services and did a short test charge, which worked perfectly. 51p per kWh, as opposed to 79p at Alnwick services a bit further south of there.
I used this method to do all the available updates to my new FL MG5 a couple of weeks ago, it took most of a day to do them all as the majority of the subsystems had updates available but I can now charge at Tesla superchargers which I couldn't before, ready to drive to Germany in a week!
Thinking of getting one just to get the job done to be fair. Trying to get a dealer to understand what needs to be done, and getting it done, is turning into a right nightmare.
Was it as straightforward as the guide suggests; installing laptop software, connecting, selecting updates, and letting it run?
Pretty much, you have to do each system one by one so I was backwards and forwards all day. The only other thing I did was leave my big 100A 12V battery charger connected in "Power Supply" mode to avoid the 12v draining. I wouldn't think you'd need one that beefy, it's just what I have.
Excellent, thanks. To be honest, I have no bugs, issues etc. with infotainment or otherwise, so I only want to update the EVCC.
£130 for the tool isn't cheap, but at least the update possibility is under my control and I know what needs to be installed rather than banging my head against the wall with the local dealer network!
I don't have a battery charger but I would hope that the battery is sufficient to allow the EVCC update only to install.
Can’t remember off the top of my head but I did have one module that ‘failed’ the update and took a further couple of attempts before accepting it. Key thing is to use a battery charger alongside, as noted above, to mitigate voltage drop on the 12v battery and don’t be afraid to persevere / keep trying if an update stops part way through (one of my main MG4 modules needed 7 or 8 goes before successful).
Thanks for the heads up.
I'd need to invest in a diagnostic tool and battery charger - the cost combined certainly isn't cheap. Perhaps in the interim I'll stick with an Ionity subscription since this brings the cost not a million miles off Tesla. I only have the car for another 18 months.
If you are only doing the EVCC you should be ok. But tbh why go to lengths of buying the kit and setting it all up and then not take advantage in doing the whole suite?
I didn’t previously get to do the TBox update in conjunction with the Infotainment system as that required tracking down separate files to be loaded from a USB stick - but plan to revisit in the coming weeks.
