towbar on MG4?
Ezza
Swindon
Hi, I'm wondering if there are any catches to avoid re fitting a towbar onto an MG4 (2023)? I'd like to use a rear bike rack & fitting it to a towbar seems to be a good option since the cradle-type ones don't seem to fit v well over the Trophy's spoilers. I've noted a post by NickT regarding a Brink detachable towbar - this seems like the best of both worlds?
Very happy with mine.
I got the this towbar off ebay, https://www.ebay.co.uk/itm/146372983081 Automatic Vertical Swan Neck Towbar + 7 Pin Wiring For MG 4 Electric, Xpower ~£200 including electrics.
Very happy with it and nearly invisible. The bumper has no visible cuts which I like a lot. As a bonus you can also re-fit the crash protection as well - so if some-one crashes into you it is much less likely to damage the car structure and write the car off. You can see the plug, it would be possible to hide it completely but that would mean cutting throught a bumper internal support which is probably fine but I did not want to do that. One thing I would say the bolt holes did not line up 100% for me, so I needed to push the 2 plates of the bar apart when fitting, no issues with the clamp type connectors for me (and others here who have used them. )
Let me assure you, that rear crash protection bar will not protect the car from being written off, I bought a salvage MG4 with 4,000kms on the clock from memory .....
The damage that was visual looked like an hrs work with a hot air gun and plastic welding a very small tear in the plastic bumper, and a bit of paint, and it would be back on the road ..... it's marked as a repairable write-off ....
When I removed the rear bumper and "crash protection bar" I found the charger broken off at the lugs and the rear panel and floor pushed in...... finding someone willing to do the paperwork involved with pulling the fold out of the rear floor, hasn't been a task I've mastered yet.
The crash bar wiped out the charger module .... well, that is what the assessor claims, I think it was more likely the crash repairer "improving" the possibility it would be written off, no crash repairer seems to what to touch an EV .....
T1 Terry
For trailer towing only? Besides adding a bike rake that isn't likely to exceeded the 50kg limit, what other possibilities is there? It's not like it would make a great off road recovery vehicle to attach a snatch strap or something .....
T1 Terry
Think it's saying small trailers only.
Obviously no Caravans or Big trailers.
That might seam like stating the obvious, but to some. 🤷‍♂️
That genuine MG tow bar, looks pretty good to me. 🙂👍
T1 Terry
After selling my ute i just need to hire a trailer from time to time
It would need to be a light weight trailer to get through the 500kg limit, forget about putting much in it. I see the new MG4 has been uprated to 750kg towing capacity ...... it might be able tow the gypsy trailer empty .... but I doubt even it would pass the 50kg ball weight unless I removed the battery and winch .......
The Gen 2 '06 Prius towed a Hyundai Getz that is the base for a Blade, first electric vehicles factory built in Australia, up the Adelaide south eastern freeway, and that is a big climb, 7 .5kms at a 6% to 8% gradient the whole way ....
Do you think the MG4 could do that?
T1 Terry
T1 Terry
More than adequate for the jobs I want to do, I’m not a heavy haulage contractor😂
    Votes: 1,045 77.8%
    Votes: 202 15.0%
