gdog
- Apr 8, 2024
- Location
- Londonderry N Ireland
- MG4
Oh! That’s that idea blown out of the waterNot sure I'd agree with that
Apologies replace ***s with ***********Those aren't useable links; you've copied shortened versions.
We'll see. You sound certain do you know something?V2G won't be using the car's inverter
Apologies replace ** s with ******
For the reasons mentioned in my earlier posting I guess - complexity and efficiency.We'll see. You sound certain do you know something?
It still means you get to plug something into the car and it powers the house(s), just that the box the cable is connected to is bigger and more expensive than you might be hoping for.We'll see [ Re V2G won't use the car's OBC/inverter ]. You sound certain do you know something?
I met a technical manager for MG on their stand at the Sydney Everything Electric show in March. Apparently V2G is "being looked at"On the back of some surprisingly progressive news here about the V2G standard to be approved in Australia, what are everyone's thoughts about the future possibilities for the MG4?
Batteries on wheels: Australia to allow vehicle to grid installations by end of year
Bowen says that agreement on new standards means that EV owners will be able to use vehicle to grid technology - effectively using their cars as batteries on wheels - by the end of the year.thedriven.io
I realise that you can already rig up something similar today using the MG4, V2L and an inverter generator input under some circumstances, but I'm hoping this standard might mean other mainstream options may be released.
The chance of MG releasing any kind of software update to enable for V2G to existing cars is probably zero. But I'm thinking maybe in future a wall charger with V2G compliance could simulate a disconnect and reconnect as V2L to switch the existing connection over from charging to discharging?
Since here in sunny WA, the daytime solar FIT is 2c/kWh (odd how they still charge everyone else over 31c/kWh for usage at the same time of day?), it would be great to be able seamlessly shift that cheap power into the evening.
Around the world, most people use a VE Quattro type system.I met a technical manager for MG on their stand at the Sydney Everything Electric show in March. Apparently V2G is "being looked at"
One issue is the reduced battery life by running it through more cycles; and how that impacts the warranty.
Interestingly I asked an electrician about powering your house during a storm induced blackout. For a fee you can have a 240v adaptor fitted to your incoming wiring / meter box that is powered by a petrol generator. Activating it disconnects the house from the grid and you run modest loads from the generator. But ANY power source can act as petrol generator including my MG4. Maybe $800-$1000.
It needs to be compatible with the safety systems for the home and the power source.But ANY power source can act as petrol generator including my MG4. Maybe $800-$1000.
Doesn't sound too far off, and should align with the federal battery incentive.By 1 July 2025
I'm also closely watching this since here in WA we should be able to apply for both state and federal rebates, meaning potentially $5k off plus 30% off (though it's not yet clear if the 30% off will be before or after WA rebate).I've just registered for a home battery subsidy.
