- Sep 3, 2022
- Solutions
- 3
- Location
- Strathaven (SE SR MY22)
- MG4
Interesting - but he doesn't say how he got into the Android System menu.
Yes, hopefully we can use that as a more technical forum than here.@leonkernan I found your post in XDA, there is a development and it looks promising
MG4 Electric AAOS 9 playing (and possibly other MG models)
Hi, So I've got an MG4 EV, which uses Android Automotive 9 on an MT2712 system for it's infotainment system. So far with some help on other forums we've been able to figure out how to access engineering mode and switch on ADB. However, I...xdaforums.com
Very nice. I'm trying on R59, but the keyboard is different and holding the comma doesn't workGot it! The trick is the On Screen Keyboard.
I used the Bluetooth settings, Device name to bring up the keyboard.
Hold down on the comma until the settings appear.
Select Android Keyboard Settings.
Select Languages
Use the search box at the top to search for any Android setting.
I searched for About, went to about phone and turned on developer mode.
You can also search for Wifi to turn that on.
Works on the SE for sure, should also work on the Trophy.
Here's a video to help explain it:
Dropbox
www.dropbox.com
Well done!Yes! Found it in the @ sign in Amazon login
Everything works fine.Well done!
And the best part, we can always downgrade back to these versions, so they can't take this away from us with an update.
This seems to be a difference in the SAIC versions.Everything works fine.
It would be interesting to make our own Launcher more integrated with the native system UI, it would certainly be possible quite easily
I set Nova Launcher as default, I adjusted the size of the labels and icons on the home a bit and you can easily go back to SAICLauncher via the shortcut. After that I would like to see if it is possible to have a more human UI scaling, the SAIC APPs work at a much higher scaling but the regular apps are very small.
Of course in case of a service it is possible to set SAICLauncher as default and everything is as before
Have you tried changing the default launcher in Android Settings > Apps > Choose default apps > Home app?This seems to be a difference in the SAIC versions.
The iSmart Lite version doesn't like me changing the launcher. It always switches back to the SAIC one and doesn't offer any choices when you press the home button.
I've tested with both the Nova and Microsoft Launchers. Both work but getting back to them is very hard.
Changing the DPI is likely to break the SAIC apps.
Yes, and it shows the setting being right. The button still triggers the SAIC launcher though.Have you tried changing the default launcher in Android Settings > Apps > Choose default apps > Home app?
I think you can solve it with a floating virtual home button.Yes, and it shows the setting being right. The button still triggers the SAIC launcher though.
I'm working on it:
Yep sorryCome up request access
I tried to get a login at the end of last week, it took the payment and sent me an invoice but it didn't generate the login credentials for me.Anyone managed to get a SNW login through RMI recently, I'm going to have to give up for now until I hopefully get the chargebacks
Hmm l wonder if SAIC have stopped the general public gaining access to it?Same, I've had to give up as I'm about £100 down, not heard back from any chargeback request yet
I believe it is in the user profile.Hi, where can I see that I have a company account and not a normal?
I wanted to test this evening by purchasing 1 hour. Well I received login credentials and I was able to connect to SIPS.Anyone managed to get a SNW login through RMI recently, I'm going to have to give up for now until I hopefully get the chargebacks
Cheers, I'll try tomorrow, credit card has refunded me so I don't mind trying againI wanted to test this evening by purchasing 1 hour. Well I received login credentials and I was able to connect to SIPS.
However, do the identifiers remain the same when you buy access later?
