Diagnostic VDI, VNCI, MDI with MG4
Green is power by the looks of it, yellow is WiFi, blue is data, 4th one hasn't lit for me yet there's also a red internal LED
Not had any issues with connection via USB or WiFi so far
Only thing I'd say with issues with sips, try the latest version (currently 19/11/24)
Run as admin to make sure it's not a disk writing issue
Make sure there's a good internet connection
Updated my Trophy from R39 to R59 today, no issues, like the new HVAC screen. Not driven it yet to see any other changes.
Thanks to all for the files etc.
A bit of a picture dump for people that were interested in the VNCI connection
Some SIPS screenshots that I don't think I've posted before, file downloader is new
View attachment 32659View attachment 32660
THANKS !!!
I ordered mine. the same as you.
Do you have a tutorial please?
Glad it was something simple
If you downloaded SIPS from my Google drive the manager I used is in the same folder
I also put a newer version of SIPS on there 2 days ago, you can tell if you have the latest as they've added a verification code on the login screen
Looking at the files I'm sure there's also a newer hotfix for VDS (14 on drive, I'm sure the current is 17) I'll look at adding that later
Hello, I received my VNCI VDI3 box but I cannot connect it to the PC.
I plugged in the USB cable but this is what I see:
Would you have the procedure to follow?
Thx
Yes but the box is not detected.
Which driver should be updated?
I succeeded on another PC...
However, when I want to launch SIPS, I get the following message:
Odd that it can't read the firmware but it can read the serial, if it won't let you update the firmware I'd contact the seller & provide those screenshots
Are you running sips as admin? Might be a file access error
Hello and thank you for the feedback.
yes in Administrator... I think I have earned the right to do after-sales service on the box...
Try with another USB cable or another USB port. If it still doesn't work, try vnci device manager v1.8.
For SIPS, I had the same message because I didn't give the app time to open. Open SIPS in administrator mode and wait.
There was a comment about a guide for software updates so I thought I'd write it here where all the other info is
To connect to the car you need a Vehicle Diagnostic Interface (VDI), from what I've read a VDI2 or VDI3 for MG4, I personally ended up getting a VNCI due to supply issues, it's also substantually cheaper
it's recommended to update connected via USB but I have done some connected via WiFi which worked fine
Once you have the interface you need to install the software on a windows computer, VCI manager & SIPS for software, VDS if you want diagnostics as well (VDS requires a more powerful computer, not sure what spec)
VDS zip password is VDS3 (Google remove it otherwise)
Open
If you haven't got an account you need a company account to get the Offboard Diagnostic subscription, 1 hour is £5.92, 1 day is £16.24
When you have paid click top right where it shows your name then user profile, you'll see SNW this is the login for both SIPS & VDS
Some of the MG sites if you login it'll get you to change the SNW account password which also affects the software, if you get a long subscription it maybe advisable
Open the VCI manager, click connect (not currently in the car, might update this screenshot)
Open SIPS, login using SNW details
click vehicle identification, it'll confirm VIN click yes
you'll get lots of error messages on the car as it checks the different modules, confirm car (EH32) click yes, it'll show the configuration of the car with different pages available on the left side
You can view current versions on the car Vs server by clicking ECU Information
Connect power to 12V battery (charger/maintainer) so battery doesn't go flat during an update
If updating a single module go to Programming and Config, this allows you to program, load the config, program a replacement module
If updating multiple go to One Press, select the ones you want or select all then click next
It'll say several calibrations are required after updating, I've used the car for a while without doing these but I have also done them, doesn't seem to be any difference either way
Can't currently update TBox due to requiring a USB to be used first, don't currently have access to these files or where they're stored for dealerships, I know where thanks to a dealership but I don't have a login
If you want/need to calibrate go to Routine & select required module
Thank you for your time and well detailed expo
Well my cable has arrived, speedy from China, ordered on 27th i think. Gonna now see if i can get the required account setup to use the software.
    Votes: 965 77.6%
    Votes: 185 14.9%
    Votes: 93 7.5%
