Had the Dreaded 12V Battery Drain Overnight
It is not the locking that causes the issue it is that if you have left the car powered up and then lock it the car powers down and then locks. I suspect in most cars it is the opening of a door with the lights on after the car is not powered that triggers an audible warning but with the power down and lock of the MG that trigger does not occur.
You may want to leave the ar with the lights on for a short while in a badly lit situation as @pjmmk posted earlier.
It would be interesting to know what happens with other EVs. (I can check with someone who has a Cupra.)
I cannot blame the MG4 programmer; we spend a lot of time complaining about wanting the ability to manually control things but then expect the car to rectify if we forget to give control back to the car. And complain when it does (eg regen settings etc).
I have the Trophy and they are not all LED. Headlights are designed to stay on if you set them to be manually on (as I described).
I have the trophy and the only incandescent lamps are the indicators, the reversing lights, the fog lights and interior light, the headlights and parking lights are all LED (see the manual page 277).
My headlights don't stay on when set to manual and the car turned off.
Check closely in the headlamp cluster, you'll see that it's the DRLs that are lit when you turn the car off, not the headlamps.
There's also the Follow Me Home toggle which will keep the lights on anyway for a determined period after locking the car. :)
I don't use that but IIRC don't you have to initiate that with the dip/main beam stalk ?
Right, so not all the lights are LED as I said, so draining the 12V battery is a definite possibility.
Ah, you are right about that, I hadn't noticed it was the DRLs.
You have to power down the car via the menu buttons, then flick the stalk to initiate the follow me home function. Most cars just keep the lights on for a few minutes after locking the car. I feel MG's way is convoluted for no apparent reason.
If you leave the hazards (indicators), the interior light and the fog light on I suppose :giggle: (although I'd guess the latter will go off with the headlights).
so if leaving the car for a while, make sure the HV battery is above 50%, maybe 60% ?
Yes is is in line with most manufactuers I beleive, when leaving the car for a longer period, ie airport car park, I always ensure battery is over 50%.
Part of me thinks this issue could be helped with a better quality 12v battery, the factory one is only covered by warranty for a year! So not a lot of faith in it by MG
    Votes: 1,096 77.7%
    Votes: 212 15.0%
    Votes: 103 7.3%
