fnegroni
Stopped at a GRIDSERVE last night, arriving after 1 hour drive with 7% SoC, leaving 37 minutes later with 80% SoC.
Started charging at 7:53pm and ambient temp of 18°C
At 7:58pm it had reached 19% SoC, with the battery temperature between 27°C and 31°C and still charging at 82kW.
By 8:12pm it had reached 51% SoC charging at 67kW - battery temperature of 39°C.
In 20 minutes since beginning of the charging session it had added 82 miles of range.
by 8:23pm it had reached 70% SoC charging now at 40kW but maintaining a battery temperature of 39°C.
I could hear the battery cooling system circulating the coolant.
80% SoC was reached at 8:30pm.
The charger delivered a total of 38.62 kWh in 37 minutes, at an average of just over 60kW.
I also figured out how to charge at GRIDSERVE using the app reliably.
1. Reverse park into an available charger
2. Look for the charger number which is located high up on the post, above the screen
3. Open the app and select the charger by number
4. Plug the charger into the car and wait for the charger to connect to the car
5. When the charger's screen asks for payment, open the app and select your payment method on the app
6. Once payment has been taken on the app, the charger screen will show the payment is approved and the charging session will begin.
