Neptuneman
- Feb 17, 2024
- Location
- Richmond Melbourne Australia
- MG4
I purchased mine also from AliExpress and it was delivered in 8 days direct from China. ~ $52. I connected it last week and it works without any issues.. I did not disconnect the existing Bluetooth phone to car connection that others have reported needs doing to set it up.. I guess leaving that existing Bluetooth connection intact will allow Bluetooth connection phone to car if needed in the future. Obviously I would have to unplug the wireless adaptor for this to happen.. I did also adjust the connection time to 20 seconds and because I have an android phone I used the app that Carlinkit provided to connect to the unit directly to adjust any parameters.I connected up one of these today:
2air CarlinKit 5.0 Wireless CarPlay
2air Mini5 Pro Carlinkit 5,0 Wireless Carplay Wireless Android Auto Box 2,4g & 5,8 GHz WLAN BT Connect Plug & Play für kabel gebundene Aa CP-Autos CarlinKit 4.0 - AliExpress 34
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
I was surprised at both how compact it was and how easy it was to set up. Pretty much just plug in, connect phone via bluetooth, tap the confirmation on the car's display screen and that was it, CarPlay started up. It comes with a small piece of double sided tape so I stuck it under the centre control shelf out of sight but stuck to the front panel, not the underside of the shelf itself.
I then went into the unit's settings (use a browser on the phone you connect to it's own local IP address) to check for firmware updates (none) and to change the start up delay to 20 seconds to give the car's system time to fire up before it tried to connect. That was also very easy.
CarPlay worked no differently to being wired, nice and fast response. Mine usually has the Waze app running.
I'll see how it goes but it seems to be a good solution for wireless CarPlay in the MG4.
No delay noticed. GPS & Waze perfect.. No difference for me to using a cable to connect. Android 13 phone.How’s the delay when using steering wheel controls for forward/back/pause music, and with phone calls? Just curious as those are normally the two areas I see complaints about with a lot of adaptors (and sometimes laggy GPS) when I’ve been looking into getting one.
