I might be the one living under a rock, but the missus just got her rego bill and on the envelope it says all hybrid and ev cars in WA will need to display the blue EV tags (similar to some other states) from January 2026. Not sure how else I would’ve found out seeing as my rego won’t come through until October 2026… typical government communication.
Not only us that's got a Dumb government, then. 🙄🤪
January 26 isn't far away. that's the first I've heard of "blue stickers"
Where do we get them from???
I know I'll go to the dept of transport website, what's the bets, they may have something about it????
TBot says,
For electric vehicles, the label is a retroreflective blue equilateral triangle with "EV" in white capital letters. The sides of the triangle are 30 mm long, and the letters are at least 8 mm high. This label is affixed to a 1 mm thick metal plate and is required to be displayed on both the front and rear vehicle licence plates for electric vehicles built or modified on or after 1 January 2019 [1].
You can order electric vehicle labels online or enquire at your local automotive store. The cost for a set of two labels starts from around $10. Please note that these labels are not available from Driver and Vehicle Services centres, regional Department of Transport and Major Infrastructure offices, or agents [1].
It's a safety thing so emergency services are aware there's a big battery in the vehicle.
Not to worry too much,
When is this commencing?​
The requirements will commence on 1 January 2026. However, there will be a 12 month transitional period with enforcement from the WA Police Force and Authorised Inspection Stations for not displaying the labels not commencing until 1 January 2027.
The Winnie has two LPG tanks, the rules say you are supposed to have an LPG tag for each tank ..... if I eventually manage to convert it to hybrid, there will need to be room for yet another tag ..... maybe they'll come up with an all inclusive tag, "if it's on fire, run"
or
"Stay well clear, there might not be a baby on board, but it's still a dangerous vehicle"
T1 Terry
How do you attach them? There's something on the DOT website about voiding the plate warranty if you damage it, but I presume you can't just double sided tape the tag as that isn"t "securely enough".
In NSW when you buy an EV (or change the number plates) the plates come with the blue triangle printed on for you.
I think it's demeaning for us pure BEV owners to see them on those cheap imitation EVs commonly referred to as HEV and PHEVs :p
There is a business down the road from my work that has an "EV Only" section of parking. It tends to be filled with Toyota HEVs and Mitsubishi PHEVs.:LOL:
I have some sympathy for the PHEVs. If they are used properly and actually charged up before use then they can significantly lower carbon emissions. Problem is all actual studies show they aren't and the real world emissions are much the same as standard hybrids.
HEVs are just taking the piss.
Our Gen 2 Prius takes the piss real good, as long as there are green bars on the battery display, you can pull out and overtake near as quick as the MG4, but it's not wise to take on two A double trucks unless you have a slight uphill climb ..... when the battery runs out of capacity, you don't want to be on the wrong side of the road :eek: I will eventually return it to a plug in hybrid with some decent capacity and install the zombie inverter board so it can drive in EV mode beyond 80km/h
T1 Terry
Got mine from REPCO, they come with blue pop rivets. According to the DOT website, they need to be attached so that they don't obscure any part of a character in the rego or other wording. As I have a bog-standard plate, it will go over the dot in the middle. If you have a cool personalised plate, you may be SOL with that.
DOT page:
Electric and Hydrogen Vehicle Labels Requirements
hmmm. Requirement to wear a triangular badge. Sounds a bit familiar.
For those in WA (and perhaps others who would like to have them) I can highly recommend the EV tags from Just Add Noise.
They come with adhesive backing but also a pop rivet.
The only downside is they come in packs of 5 sets minimum, which I didn’t mind as I’ll have some for when the wife goes electric and for my electric side-by-side when it gets delivered (even though that won’t have a rego plate). The rest are a life time supply of back up I suppose.
Also, I thought it’d be smart to wipe my plates with some isopropyl alcohol, and I thought a lot of black gunk was coming off, but it turned out I was just slowly wiping of the black ink from my letters :(
For reference my plates are slimline so 372.0mm x 100.0mm.
But they're $10 at SCA for a pair if you can find stock ... which there isn't much in WA at the moment. I suspect now that it's a requirement that stock will start to trickle into the state.
I think those recent “range extender” EVs are even worse, that’s just a hybrid where the ICE doesn’t drive the wheels. They’ve just strapped a generator to the car really.
I don’t see the appeal in hybrids, you get the worst from both worlds. You’re hauling around a battery pack (with the initial worse pollution from production) as well as a heavy engine block (which keeps the pollution up with tailpipe emissions). I can see the appeal in selling them if you’re a dealership, you can still do lots of maintenance on them and make money.
SCA has stick-ons (with a hole for a rivet but no rivet supplied) and Repco it seems has no sticky backing just the rivet. Although they do come with fancy blue rivets so as not to ruin the aesthetics of your little triangle.
Thanks @decrep, you're correct, I was just Googling it.
That's opposed to conventional ICE cars carrying around highly flammable hydrocarbons that regularly ignite in accidents incinerating the occupants... But we already deal with that so, all good :ROFLMAO:
    Votes: 1,069 77.7%
    Votes: 208 15.1%
    Votes: 99 7.2%
