NLMGSAN
- Dec 26, 2023
- Location
- Ede, NL
- MG4 Trophy ER
R59 is out. Do not know if it came with a new map as well.
@Surfdog posted pictures in another thread ... the maps still seem to be 2022 Q1, so 2 years old. (I've no idea whether his Navi version is updated as I only have an SE). The search options did seem to show EV charge points, which could be selected by supplier.R59 is out. Do not know if it came with a new map as well.
Not surprized the map is still the old one. Anything above r33 did not get the map update working. So why should r59 work...@Surfdog posted pictures in another thread ... the maps still seem to be 2022 Q1, so 2 years old. (I've no idea whether his Navi version is updated as I only have an SE). The search options did seem to show EV charge points, which could be selected by supplier.
Same here, but I used the map data I downloaded a few days ago........Its frustrating and it shouldn't be this hard as its what we paid for with the Trophy version, but getting closer.Received a new link from MG.
https://iov-mapmg.soimt.com/#/downloadMap
This one recognises my VIN and generates a VN.txt file. Downloading now……
Update: no longer get the VN error but I still can not update. When I click on ok on the resource screen, it takes me back to the instructions screen - clicking ok takes me back to the resource page and so the cycle repeats.
Need to check this resource upgrade in setting1.Export the fingerprint file from your vehicle by using U-disk.(You can export it from the resource upgrade in setting on vehicle)
so what you re saying is that this Fingerprint file is only related with the base 51KWh model ( and nothing to do with the Luxury/trophyLR model ???The fingerprint file is supposedly needed if the car has ismart lite (without esim/internet connection) like the MG4 base model
The VN file is used for map activation, based off the VIN (and probably some API that the car itself checks to activate the map)
In other words, the vin should be sufficient?so what you re saying is that this Fingerprint file is only related with the base 51KWh model ( and nothing to do with the Luxury/trophyLR model ???
If thats the case then I'll test the generated Vn.txt to see if it works or I obtain the same result reported up
You actually installed new maps?https://iov-mapmg.soimt.com/#/downloadMap now it's working. I could download VN.txt file and download maps
I know - it was a very loooooong shot. And you're more than right the zip extraction is sooooooo loooong also that its a waste !!!Don’t waste your time - it makes no difference
23GB isn't bad for maps of the whole of Europe. IIRC, map updates for the Zoe ran about 20, with a lot less charging station POIs listed.I know - it was a very loooooong shot. And you're more than right the zip extraction is sooooooo loooong also that its a waste !!!
Back to the usual Google MAPS/ WAZE it is ....
Shame that all upgrades/UPDATES being maps/or infotainment/car different firmwares is so BUGGED -or worse- DEPENDEDENT OF SAIC, AND NOT WORKING AT ALL ...
I can understand WHY OTA arent either active- With a SMALL MAP update of 23GB !!!!!!!!.
they love to announce a la TESLA but SAIC is Still in the XIX century... for this still trying morse code
23GB transmited in morse code -SURELY gets bugs Everywhere...
I agree if you're doing the download @home and copying it to an USB tick... But if you say that you'll offer OTA updates - on a 4g ESIM that probably is Capped to 5GB - then its a Issue - of a badly Announced OTA; and a badly designed update.23GB isn't bad for maps of the whole of Europe. IIRC, map updates for the Zoe ran about 20, with a lot less charging station POIs listed.
