I think you got that the wrong way around. This is the ZS forum. :)
This thread was in the MG4 board - it's been moved. ;)
I rarely if ever visit the ZS board - no reason to - yet I also replied earlier. Why would that be do you think? ;)
This is the correct answer, but I will add if you zero your trips you may get closer to the WLTP range but as you start driving it will continually adjust the range based on your historic and current driving style.
That's really interesting, I hadn't appreciated that it takes historic and current driving style into account.... Every day's a school day!
Morning Forum,
I have a MG ZS EV Trophy Long Range, I have had the car from new and it was delivered about 6 weeks ago. All the literature that I have for the vehicle mentions the range for the Long Range being 273 miles when fully charged. I find that extending the battery to long Range journeys (100%), I only get between 208 and 213 miles from a full 100% charge.
Is this right and if so, how/why?
I'm I right in thinking it would only so 208 to 213 on 100% charge? Or is this just what is displayed?
It says 2 between 208 and 213 miles when its been fully charged to 100% but in reality, it's even lower than that due to driving due with lights, heater, radio, etc....
We will be driving to an airport and leaving the car for a month do you think we will get there and back its a 130 mile round trip, or am I over thinking it?
There are topics on this in the various forums, I seem to remember try to park with over 50% charge, have a fully charged jump battery pack under the drivers seat in case the 12V battery has gone low and know how to use the emergency key. If you do all of this it will probably be fine. :)
Following a journey of just under 200 miles to Northumberland I tried to top up my ZS EV Trophy Long Range. The maximum it reached was 220 miles and in the three months since then it has not gone higher. In excess of 270 miles was quite normal before. Chorley MG were kind enough to try & diagnose any faults but none could be found. I will be contacting MG but wonder if this problem has been observed by any members. Thank you. Graham Luke
I think all these could do with merging together.
We are getting about 120miles on a full charge. November 2020 Exclusive.
What is your full charge reading. Is the battery balanced. How do you charge.
All have bearings on the range.
Thanks and sorry for my late reply. I hadn't realised I had received so many replies :). I have charged the car 4 times so far, 3 were rapid charges and one was 7 kW charging station. Last charging was on 2 January. The car was 100% charged and it was showing 159 miles in Eco mode. I have driven 51 miles since then within the city, with no motorways, and the mileage shows 35 miles on Eco mode.
I am not sure what a balanced battery is, if you can elaborate on that that would be great.
My 2020 ZS EV is doing about 130 miles over the past couple of days (between 60 and 70 on 50%) on a mix of motorway and A roads. This morning I only put the heater on to take the chill away then turned it off until it felt chilly again and had 4.1mi/kWh for the journey. I tend to stick to 67 mph using ACC on motorways and maximise regenerative braking the rest of the time. SOH is 92.5% and a balancing charge is done every 3-4 weeks.
Thanks and sorry for my late reply. 130 miles is quite good. How do you monitor SOH please?
Are you leaving home with 100%?
If so, is it possible to heat up cabin before you disconnect the charger?
What are your tyre pressures like? A drop in tyre pressure will see a drop in range.
Is there any unnecessary weight in the vehicle (junk in the trunk, etc)...?
I now do just a few miles a day, all within the city. I would say 3 mile/day average. I last charged the car on 2 January to 100% and it was showing 159 miles in Eco mode. I have driven 51 miles since then within the city, with no motorways, and the mileage shows 35 miles on Eco mode!
Range depends on quite a few factors, speed and use of the AC to name but two. When I had a Gen1 model it did not have the new BMS update which reduced estimated mileage to 163, so the estimated range was around 178 in mild to good weather and down to around 155 in poor weather. One very important thing on maintaining battery health is re-balancing. If it has not been re-balanced for quite some time then if I remember correctly the battery has to go through multiple rebalancing cycles to normalise itself. I’m sure someone better than me can advise on this if I am wrong.
I used to do a round trip of c100 miles in my Gen1 of which around 36 was on the motorway. I drove about 60mph, sometimes a bit more but not often. You soon get used to people driving slower than that! I installed Autoclover wind deflectors to try and minimise use of the aircon to demist the windscreen in cold and wet weather (I currently also use the shaving foam method too, because range is important to me). Some time ago a member created a very useful list of things to think about to maximise range. I’ll see if I can find it and create a link to it.
Generally speaking, when checking EV mileage to actual mileage, then depending on the weather and adopting some general principles on how the car is used, I would be either 10% up or down.
Thanks for the advice. I am not sure if the battery is balanced, As I have only had the car for less than a month. How do I check if I have the latest BMS, please? Mine shows 155 miles and gives my 70 miles, so about 50% error in the estimation.
MG exclusive 2020 model with slightly under 95%SOH
I did Birmingham to Cardiff 110miles on Sunday was about 2°C with 2 adult passengers and full heavy load. Was panicking a little towards the end but did manage it on a single charge.
I find best to keep motor power as close to 15% as possible. Speed will vary between 55 to 70+ mph depending on up or down hill) occasionally upto 30% power but no more for long-distance driving.
That is amazing. How do you check your SOH please?
Zan - you will soon learn the rules of ev driving for longer journeys:
50 -65mph max speed, the slower the better
No heat or fan, or absolute minimum use for safety
No use of ACC, maximum regen always, use econ too
For long journeys - plan carefully using zapmap or similar
thanks, sorry for being totally ignorant but what is econ please?
