MG4 variants worldwide past and present
Status
The first post in this thread is a WikiPost, and can be edited by anyone with the appropriate permissions.
Stuart Wright
Administrator
Staff member
Birmingham, UK
Not an MG
MG4 variants past and present. Updated January 2026.
E&OE. I.e. if you find an error and you're an Established member, please feel free to edit this post to fix it.
TerritoryModel / grade (battery)Launch (year)Update (year - change)Current (as of Jan 2026)
United KingdomSE Standard Range (51kWh)20222025 - battery shown as 49kWh for SE Standard RangeSE Standard Range (49kWh)
United KingdomSE Long Range (64kWh)2022NoneSE Long Range (64kWh)
United KingdomTrophy Long Range (64kWh)2022NoneTrophy Long Range (64kWh)
United KingdomTrophy Extended Range (77kWh)2023NoneTrophy Extended Range (77kWh)
United KingdomXPOWER (64kWh)2023NoneXPOWER (64kWh)
Europe (many markets)Standard Range (51kWh)20222024 - MY2024 brochure shows 49kWh offeredStandard Range (49kWh)
Europe (many markets)Comfort (64kWh)2022NoneComfort (64kWh)
Europe (many markets)Luxury (64kWh)2022NoneLuxury (64kWh)
Europe (many markets)Extended Range (77kWh)2023NoneExtended Range (77kWh)
Europe (many markets)XPOWER (64kWh)2023NoneXPOWER (64kWh)
AustraliaExcite (51kWh)2023NoneExcite (51kWh)
AustraliaExcite (64kWh)2023NoneExcite (64kWh)
AustraliaEssence (64kWh)2023NoneEssence (64kWh)
AustraliaLong Range (77kWh)2023NoneLong Range (77kWh)
AustraliaXPOWER (64kWh)2024NoneXPOWER (64kWh)
New ZealandExcite (51kWh)2023 (not dated on the source used)NoneExcite (51kWh)
New ZealandExcite (64kWh)2023 (not dated on the source used)NoneExcite (64kWh)
New ZealandEssence (64kWh)2023 (not dated on the source used)NoneEssence (64kWh)
New ZealandLong Range (77kWh)2023 (not dated on the source used)NoneLong Range (77kWh)
New ZealandXPOWER (64kWh)2023 (not dated on the source used)NoneXPOWER (64kWh)
SingaporeTrophy (150kW, 64kWh)20232024 - 99kW version introduced (battery stays 64kWh)Trophy LR (99kW, 64kWh)
SingaporeTrophy LR (99kW, 64kWh)2024NoneTrophy LR (99kW, 64kWh)
MalaysiaStandard (51kWh)20242025 - discontinued (no longer in updated line-up)Discontinued
MalaysiaLux (64kWh)2024NoneLux (64kWh)
MalaysiaLux Extended Range (77kWh)2024NoneLux Extended Range (77kWh)
MalaysiaXPOWER (64kWh)2024NoneXPOWER (64kWh)
PhilippinesStandard (51kWh)2023NoneStandard (51kWh)
PhilippinesLux (64kWh)2023NoneLux (64kWh)
PhilippinesXPOWER (64kWh)2024NoneXPOWER (64kWh)
VietnamDEL (51kWh)2024NoneDEL (51kWh)
VietnamLUX (64kWh)2024NoneLUX (64kWh)
IndonesiaMagnify (51kWh)2023 (not dated on the source used)NoneMagnify (51kWh)
IndonesiaMagnify Max (51kWh)2023 (not dated on the source used)NoneMagnify Max (51kWh)
TaiwanBase model (64kWh)2024NoneBase model (64kWh)
TaiwanXPOWER (64kWh)2024NoneXPOWER (64kWh)
ThailandStandard Range D (51kWh)2022NoneStandard Range D (51kWh)
ThailandStandard Range X (51kWh)2022NoneStandard Range X (51kWh)
MexicoStyle (51kWh)2024 (not dated on the source used)NoneStyle (51kWh)
MexicoExtended Range (77kWh)2024 (not dated on the source used)NoneExtended Range (77kWh)
MexicoXPOWER (64kWh)2024 (not dated on the source used)NoneXPOWER (64kWh)
I believe early on the Chinese had a cheaper version without MG Pilot and all those safety systems .
What happened in Singapore ( local regulation ??? ) to have their versions strangled by a third, must have been done electronically , MG/SAIC would not have made a new motor just for that market.
In the Netherlands the ranges were/are
Standard ->Comfort->Luxury->Trophy Extended Range->XPOWER
Source: MG4 Electric - Entscheide dich für mehr
Make sure you include the region and language if it "auto" corrects it at page load.
That means the Netherlands did not follow Europe's naming convention for the model with the 77kWh battery
Status
    Votes: 1,077 77.8%
    Votes: 208 15.0%
    Votes: 100 7.2%
