Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4
You're shown as driving "not an MG" - can you edit that?
Check the warranty docs ... the permitted SoH up to 7 years is 70%. If the SoH falls below that within the warranty period then the battery pack will be repaired or replaced as necessary.When i purchased my MG4 they did not specify the degradation %. They only gave me a 7 years or 128,000km EV Battery warranty, which mean nothing without a degradation %. So how can one check and claim for example a battery replacement.
@Barbette which dealer was that? Paul Rigby MG Redditch?I had my first service yesterday, Trophy LR 8,350 miles, the Battery SOH on the Maintenance Check Sheet they gave me is shown as 10066% - I doubt that's correct
I did get a software upgrade which was technically described as "The big one", no idea what it really included except that I did get R46 Infotainment.
They also provided an A4 sheet of paper for the Service History Report that has space for 6 services to be recorded (date, mileage, dealer stamp and signature). I guess they decided to do that to placate all the customers who were unhappy with the "Service Record is only available online" stance.
That's the same for us here in NZSo in UK the first service is 1 year? Here in Australia the first service is 2 year or 40,000km.
Same car, why different service intervals?
I think the LFP pack only has a 250Wh bottom buffer to stop it being completely discharged if you run out of charge. They are a lot more tolerant of low SoC so don’t need it.Yes, and it was 95%. (Which is not unexpected after the first year for an LFP pack ... there's not as much "buffer" on the LFP pack vs the NMC pack, so an NMC pack can degrade without the headline SOH being noticeably affected). After another year I'm somewhat expecting the SOH will still be 95%, or maybe 94%. (Degradation of LFP flattens out after the initial drop).
The battery for the Tesla model 2 sounds incredible if the stats are true. Same manufacturer as the MG4 battery, CATL, but new LFP technology that can charge at over 300 kW and isn’t affected negatively by low temperatures. That’s probably one of the main drawbacks of buying an EV now. Not battery life but the technology moving on so fast that any new car you buy is obsolete in a short period.Agree but upgrading these cars in the future with new battery tech giving much more range, less sensitivity to temperature and carefree charging will be a big business as prices for these components will become much more 'commodity' related
I also picked up on this in recent days, if the model 2 is anything like the mockups and 25K price tag, then I'd be very interested in 2 years timeThe battery for the Tesla model 2 sounds incredible if the stats are true. Same manufacturer as the MG4 battery, CATL, but new LFP technology that can charge at over 300kw and isn’t affected negatively by low temperatures. That’s probably one of the main drawbacks of buying an EV now. Not battery life but the technology moving on so fast that any new car you buy is obsolete in a short period.
If it helps mine at 20,000 miles is 5% degredation, but the algorithm/trend has curved to a linear trend, which extrapolates to something like 10% degredation at around 250,000 miles - I can charge 64% overnight with an ohme charger, so once its less than 1/2 full I plug in & add upto 64%.I’m curious if that has any effect on LFP degradation.
Me too. Though I’m really not a fan of the move towards shoving everything on a touchscreen that Tesla started and everyone else is copying. One of the things I much prefer with the MG4 over the Cupra Born I had is that it’s easier to live with ergonomically.I also picked up on this in recent days, if the model 2 is anything like the mockups and 25K price tag, then I'd be very interested in 2 years time
FYI, if you’re on Intelligent Octopus GO you can add as much as you need. Almost everyone thinks you’re restricted to the off peak period for cheap charging but you aren’t. I thought that too but it says ‘all smart charging’ and although there is a fair use policy, it is otherwise true.If it helps mine at 20,000 miles is 5% degredation, but the algorithm/trend has curved to a linear trend, which extrapolates to something like 10% degredation at around 250,000 miles - I can charge 64% overnight with an ohme charger, so once its less than 1/2 full I plug in & add upto 64%.
Impressive - I'll probably switch to this after May 24, but for now I'm still filling my boots via EDF at 4.5p / kWh, last year I took 6000kWh off peak and 100kWh peak - so electricity cost around £300, with octopus its going to be nearer £500 going forward, nevertheless all fine n dandy! Cheers!FYI, if you’re on Intelligent Octopus GO you can add as much as you need. Almost everyone thinks you’re restricted to the off peak period for cheap charging but you aren’t. I thought that too but it says ‘all smart charging’ and although there is a fair use policy, it is otherwise true.
Unless you override the schedule by using the max charge function on the Ohme EVERYTHING the charger schedules is at the cheap rate.
If you try to game it then you’ll probably break the fair use policy but I normally only charge the car a couple of times a week at home. In this example my plans changed and I needed the car in the evening.
Exhibit A!
Blimey, you got yourself a good fix there! ?Impressive - I'll probably switch to this after May 24, but for now I'm still filling my boots via EDF at 4.5p / KWh, last year I took 6000kw off peak and 100kw peak - so electricity cost around £300, with octopus its going to be nearer £500 going forward, nevertheless all fine n dandy! Cheers!
