Diagnostic VDI, VNCI, MDI with MG4
The front Camera is not the FVCM Module. The FVCM Modul is the Camera for Lane Assist (in Rear Mirror assembly) and won't be visible to the user.
You seem to have issues with the Data stream or Analog Video (not sure based on quality it seems to be analog) from the Camera(s) to the Infotainment. Are all Cameras blue or just front (in the front Bumper) and the side and rear cameras are working? Could be wiring issues or issues with the FICM (Infotainment) Module..
Just front camera. The original front camera had to be replaced. The rest of the cameras are working. I currently still have the LKA light on te dash as well? Is that caused by the FVCM module?
So possibly the connection to the camera is just not correct or the connection cable is defect. Was it changed after an accident? Could be also possible during change that connection is not fixed or cable was cut. If you get a warning of FVCM Module for LKA you may need to start a recalibration, not sure how to proceed with this. This could be the case because you may have repeatedly try to update/replace this Module, which was not necessary.
360 cameras plug into the FICM, the FVCM is connected to the can bus
You think reprogramming the FICM would do it?
Why don't you check the wiring first? The FICM might not have a problem.. problems won't go away when you only try to update things when wiring or the Camera is maybe the issue?!
Or just Visit the Dealer...he should help..
Can you clarify exactly what you mean please?
So the lane keep assist warning light is on but my car still buzzes me when I veer into another lane but after installing my radar and lights went off my dash I expected tbis to go off too but now I assume it is related to the camera ?
Hello! I´m searching for a way to set some things on a MG4 like I know it from other Cars (VW = VCDS for example).
Is it right, that it is still not possible until yet?
Not possible, at least not with public tools currently available. Would be nice though.
Disabling things like TPMS, seat belt reminder, LKA would be hella nice.
Hi, I want to update MG4 comfort SWI69-29958-1100R13 MCU 69.1.1.1 to a more updated version, can I do it only from a usb? is there a guide here and relevant drive files? thanks
    Votes: 1,031 77.6%
    Votes: 201 15.1%
    Votes: 96 7.2%
